Question about Brother XL-2230 Mechanical Sewing Machine
Cannot not pull up the bobin thread this is so simple
Had machine nearly a week now still have not used it so please can some body help
    Problem Solver:
  • 9 Answers
Make sure it is threaded correctly and make sure the needle is not in wrong. The flat of the needle should be to the rear of the machine and there is a groove that runs the length of the needle which will be towards the front of the machine.
Posted on Dec 27, 2008
I have multiple threads coming out the bobin space and making a mess of the back side.
called bird nesting and is a result of too loose a needle thread tension
if you use an automatic tensioner or using the numbers
and you still have a problem, the correct tension is a resistance to you pulling the thread prior to threading the needle
Feb 08, 2018 | Sewing Machines
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
Is there any other thing I can do to stop the thread from the upper looper from breaking after about 30cms of sewing. there is no sign of it being about to break. I have changed thread, needles and...
it could be due to one or more of the following
  • Threading is not correct.
check that bobin is not snagging thread,
remove bobin and remove any dust and fluff from bobin area
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Correctly thread machine.
  • Replace needle with correct size.
  • Properly insert needle.
  • Start machine at a medium speed.
  • Check threading order.
I hope this was helpful
Jan 05, 2011 | Husqvarna Huskylock Computerized 910
How can you fix the under threading of a sewing
Check the ovious things first make sure you needle isnt broken... then make sure there isnt any thread twisted inside your bobin housing. make sure bobin is inserted correctly if those things dont help it could be an issue of timing in your machine... I work as an embroidery operator in a factory setting and those things usually help..
Apr 08, 2010 | Singer 3116 Simple
Thread keeps breaking while sewing
If you have a manual look for checking the tension. Or it may be it is threaded wrong.
Jan 26, 2010 | Brother Sewing Machines
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
I can't find my manual and cn not get the bobbin to thread correctly
you need to insert the bobbin so that when the thread pulls off it spins counter clockwise. on the side closest to you there is a notch that you slip the thread into and then pull along the side towards the back of the machine staying on the left. once you've done that you can manually turn the knob on the side to make the needle cycle down so that the upper thread will pull up the bobbin thread.
Nov 25, 2007 | Singer 6038 Mechanical Sewing Machine
My machine is locking and apparently tangling up inside of the bobin case
You also need to adjust the pressure foot on the top of the machine. This regulates how much pressure is put on the fabric and the feed. Sounds like it is wrong somehow-maybe you need more pressure. Check the pressure adjustment is screwed in properly if it is this type which unscrews.The pressure adjuster Im reffering to is generally a silver colour and looks a bit like a basic tyre pressure guage or pressure cooker valve-it just got a cuple of lines on it and sits on the top left of the machine above the needle bar. The other thing which could cause problems is the bobbin tension-make sure it is running thru smoothly but not too loose.
Sep 06, 2006 | Singer 3343 Mechanical Sewing Machine
Brother XL-2230 Mechanical Sewing Machine Logo
74 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
