Question about Whirlpool Dishwashers
Whirlpool gc2000 disposal not draining
My gc2000 whirlpool disposal isn't draining. when i turn it on, the liquid and stuff will bubble up from the disposal and it sounds like it is working, but it takes several minutes for everything to drain out. how would I fix this problem
  • 1462 Answers
SOURCE: Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Posted on Apr 04, 2007
  • 18 Answers
SOURCE: whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Posted on Jan 13, 2009
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: Whirlpool dishwasher DU1145--need reset codes to restart machine
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
Posted on Dec 22, 2010
Macmarkus
  • 2605 Answers
SOURCE: the dishwasher does not drain, i just replace my
Hello, Welcome to FixYa. I just came accross your post and immediately I thought, " drain plug in garb not punched out" this is very common when a new garb or dishwasher is installed..so much If I had a dollar for every one I saw or heard about I could be paid a couple of trip charges. If you haven't already done so, remove the drain hose from the garb and knock out the stop inside the spout. See your installation guide/owners manual ( for the garb/disposer ) if you still have it, that should show you "where" and "how". Let me know either way and I'll help further if necessary. Regards, Macmarkus :)
Posted on Feb 22, 2011
Whirlpool gc2000 garbage disposal leaks from bottom of unit
if the leak is minor, spray Leak stoppers available at hardware stores. if major, may be a gasket needs replacement.
Oct 10, 2013 | Brasstech 113/01 Garbage Disposer Stopper,...
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Ace 2000 clogged grbage disposal backs up water
Take apart the tubular drain under the sink.
Put bucket under the disposal and turn on disposal. Stuff should come flying out.
Hang some rags over the disposal to direct stuff downward.
Clean P-trap and reassemble tubular drain pipes.
Open following link for for tubular drain pipe tips:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 26, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Not draining water after cycle has completed
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 24, 2009 | Whirlpool Dishwashers
Whirlpool du920 dishwasher not draining after wash cycle
Hi
Thanks
Rylee
Dec 11, 2009 | Whirlpool 24 in. DU920PW Built-In...
Will not drain
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 03, 2009 | Whirlpool Dishwashers
My dishwasher is not draining
Hi
Thanks
Rylee
Nov 09, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher washes dishes but does not drain...I unhook the dishwasher drain line and blow air threw it and then hook back up and hit the cancel/drain button and it empties???? whirlpool model du920gwdgo
Hi
Thanks
Rylee
Nov 03, 2009 | Whirlpool 24 in. DU920QWD Built-in...
Dishwashers Logo
817 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
