Question about Bosch WFMC 3200 Front Load Washer
Dirty water At the end of the drain hose there appears to be a filmy grey colored film. Does not have any smell but feels slimmy. The whites are cominig out grey. Any ideas for a quick fix.
  • Bill Loncar Apr 03, 2007
    thanks for your help. you solved the problem.
There is a mold growth problem within the hoses and antisyphon device of this machine as well as in the gasket around the door. You can clean the hoses by taking off the back of the machine (unplug first!), then disconnect the hoses from the back of the drain pump. Remove the hoses from inside the machine and then soak then in a sink. You will most probably find that the antisyphon valve is covered in mold. Take apart the antisyphon valve by turning the pieces. BE CAREFUL as there is a small ball inside the valve. Soak this piece in bleach. While this is not a permanent solution, it does give a bit of relief.
Posted on May 13, 2007
  • 1,462 Answers
Are you using liquid detergent? if so, don't. liquid detergent has the side effect of leaving a nasy smelling slime inside the machine and think this is what you are seeing on the drain hose. if i'm right, put appliance oin boil wash when empty and use powder detergent
Posted on Mar 31, 2007
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
I have a low water use LG front loader and white synthetics are turned grey no matter what cycle I use and even when I only place them in with other white or pale colours. It is especially bad with...
Have you checked to make sure your not getting water syphoning back out of the drain hose into the tub? this is the usually cause for this. Dirty water is getting back in. The hose should be at least as high as the back of the machine with a elbow on it or an anti syphoning kit should be used.
Mar 23, 2011 | LG WM-2277HW Front Load Washer
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
Feb 06, 2011 | Bosch SHX55M02UC Built-in Dishwasher
It' no longer cleaning my dishes
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
Oct 23, 2010 | Dishwashers
Our Duet just doesn't clean very well anymore. There's soap residue in the clothes sometime, and the clothes don't always smell clean. Are there any filters to clean out? Is there a way to get it to use...
The drain is probably clogged and the dirty water is going back into the washer. This happened to us, and the clothes were getting grey and dirtier than when they were before being washed. Make sure the drain pipe drains well, check hoses and clean the machine.
Dec 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining
clogged drain if its tied into to the G/D I would start there.
Sep 12, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Bosch WFMC 3200 Front Load Washer Logo
71 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
