Question about Motorola Mobility RAZR V3
Top 3 Buttons Won't Work Because Of Battery
My Battery is pushing onto my keypad and pushing the top 3 buttons out which makes it really hard to press them
  • Kraybee Dec 26, 2008
    They tell me the phone is without warrenty even though the company i bought it from swears blind its still in warrenty
    Brigadier General:
  • 7,752 Answers
That is strange maybe you should take the phone into a mobile service center and have the phone looked at.
Posted on Dec 26, 2008
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
On my SGH-A737 some times my buttons won't work so
pull it apart and clean the contacts with a rubber eraser where the silicon buttons push onto it . if you google this up there will be a link to show you how to pull it apart it is not that hard to do. regards terry PS.it is under samsung and your model number.just type in how do you pull apart samsung etc ther are pictures to guide you through it..
May 23, 2011 | Samsung Cell Phones
I have several Intermatic Model DT7.It very hard to set hours and minute. I press the buttons and nothing hapens and the just start to go up through the numbers and I can't stop it.
I'm not sure what timer you have.
Programmable timers are made so you press-and-hold the button, and then display goes up through the numbers as you describe.
I test timers, and have not seen the fault you describe. 4-6% of timers arrive defective.
However you have several timers that do the same thing.
If you press the button once, then the first number shows, press button again and next number shows.
If your timer is going up through the number with one push of the button then try resetting timer.
I cannot identify your timer to know what the reset steps are.
Also, many timers you push the + button to go up through the numbers, and push the - button to go down through the numbers > try both buttons since one may be made for individual selection and other for acceleration through all numbers.
If timer operates on 120V, perform circuit analyzer test on the circuit to eliminate electrical as source of problem.
If this is a hard-wire timer, carefully review of wiring.
If you find the specific source of problem, add a comment.
Securitron makes DT7 programmable timer
To see image and identify timer:
http://absupply.net/securitron-dt-7-prime-time-digital-timer-6071.aspx
On-line manual shows on page
Intermatic shows DT300 series has been discontinued by Intermatic:
This timer also sold as Woods 59203 and GE 15091
To see image of timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
Intermatic shows DT17 timer:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt17c%20-%20english.ashx
DT27
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt27c%20-%20self%20adjusting%20-%20english.ashx
DT121
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How can i format my n5800
on soft formatting:
*#7370# should still reformat the 5800 in the same way it re formats any S60 2nd edition or later phones.
on hard formatting:
try this to your phone. turn off your phone. then follow these instructions.
press and hold the following 4 buttons till the phones restarts completely.
1. hold the green button used to accept calls.
2. hold the * keypad
3. hold the number 3 keypad.
4. hold the power button located at the top of the phone.
press and hold the buttons until the phones starts by itself. it will take some more time to start in this way and remove your memory card and do it.
Nov 04, 2010 | Nokia 5800 XpressMusic Smartphone
Our liftmaster keypad doesnt open the door when code is pushed in unless you press hard. Does it need replacement? Battery was changed
Yes the buttons are worn out. Make sure you get the same model number. There are some that look alike but will not work properly.
Jan 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need to know how to unlock my tmobile vario device without using the touch screen because it has cracked. I can press a button to 'unlock' then it displays 'tap unlock or press *' However I cannot...
Phone Lock Reset Wizard Mda Vario T Mobile
instructions for
hard resetting a wizard, which is resetting the phone
thus the phone lock as well.
Dead easy really
1. Press the Comm Manager button (top left)
together with the Voice Activation button (top right)
for 2 seconds.
2. Keep holding the 2 buttons above and press the soft reset
(middle right little hole) with the stylus for another 2 seconds.
3. When the black screen appears it'll ask you to click Send
That's it All done !!
The wizard's going to reboot and reset himself.
Good Luck.
May 17, 2009 | T-Mobile MDA Vario Smartphone
Motorola RAZR Battery Pushes On Keypad
take the phone to a mobile service center and hvae them looked at the phone.
Dec 19, 2008 | Motorola Mobility RAZR V3
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
My Touch pad does not work, can someone help? kenmore mocrowave model 721.62624200 microwave buttons work sporatically. if i push in a downward motion they work sometimes microwave blew a fuse a couple of...
It sounds like the keypad is worn out. The fact that you can get them to work sometimes by what direction you push on them, tells me that the contacts are not working correctly.
Did you have this problem prior to the fuse blowing or did it start after you replaced the fuse?
I don't believe the fuse blowing is related to the keypad problem. I also don't believe that you have a microprocessor problem because you say that the function buttons work but the number keys don't work right. If the microprocessor was faulty, it would not be able to read any of the keys.
The fact that the number keys are not working doesn't surprise me. When you go to cook something, you will press the number keys several times, while only pressing start or stop once. This is why your number keys have worn out first. These keys have a limited number of cycles (presses) and it sounds like its time for a new keypad.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Microwave Ovens
Blackjack keypad not working
it could be that your phone could have goten bricked which means that it locks your phone aka virus its very comen with all this 3 party software or the software made your phone have a system error makeing you have no way of fixing it phones are hard to fix not like a computer so your phone maybe done.
Aug 18, 2007 | Samsung Blackjack SGH-I607 Smartphone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
