Question about Dryers
Underwire from a bra is stuck behind drum - Dryers
    Scholar:
  • 111 Answers
You wouldn't believe how common that is. If you can see part of the underwire, unplug the machine first! Then, try to pull it out through the holes in the rear of the drum with needle nose pliers or vise grips. I can't stress enough the need to unplug the dryer first. On certain brands the heater is right behind the rear panel and depending on certain circumstances there could be 120-240 volts to the heater even though it is not hot and the underwire could either be shorted already or will short when you try to pull it out.
Posted on Dec 19, 2008
Maytag Nuptune washer in spin cycle sounds like a plane taking off
Something small, like a paperclip or the wire from an underwire bra can get stuck in the holes in the drum, and rub against the outer drum. You will have to check carefully to find it.
Mar 16, 2012 | Maytag Neptune MAH5500B Front Load Washer
Grinding while tub is turning
There is probably something stuck in the drom or the drum seal. I would check for the underwire from a bra this is a commmon problem the wire comes out and gets stuck in holes in the drum.
Mar 04, 2010 | Maytag NFW7200TW Front Load Washer
Bra underwire stuck in Bosch WAE22461AU
You can try using a very high strength magnet to bring the clip up to a hole in the tub so that you can then use a pair of fine long nose pliers to grasp it and reef the little blighter out!
Patience Does It !
Oct 24, 2009 | Washing Machines
Bra wire stuck in the drum
Are you from outside the United States? I tried running the model number in our system and it does not come up as submitted. In the GE/Hotpoint Look-up there are only three models listed...Without a good and verifiable model number, I cannot help further.....
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire stuck
you may not have to take the washer apart, take a good ligtht and look around inside the spin tub, if a part of the underwire is sticking thru, try and pull it out. Do not use the washer until the wire is removed or it actually could cut the tub and then the machine will leak $$$
Let me know the make and model if you need more assistance
T
May 22, 2008 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Dryers Logo
190 people viewed this question
Top Dryers Experts
Marvin
Marvin
