Question about Welding Tools
Im tryint to conect my wire feeder
I have a miller axcess 40 v wire feeder stock# 195182 axcess-s serial# lg025231 then i have a miller invision 456p dc- inverter arc welder stock#903505 serial# lf152585 im trying to conect my wire feeder to the base unit arc welder the feeder has a data cable millier electric p/n 202573 but the remote cable for the feeder does not fit the remot plug on the arc welder can i get an adepter or a wireing diagram to show me which wires do what from the feeder so that i can hard wire the feeder remot cable to the arc welder its easy to get to but im not sure which wires would need to go whare
Ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Posted on Dec 27, 2008
What does NET WAIT stand for on my miller axcess 450 and how do I get it to go away/fix it?
So I spent half a day swapping boards from a good 450 axcess from what I found between testing and the manual the net wait stands for network updating. The problem I had is the pc7 board (user interface card ) had a burnt spot on the solder joint for the ground I replaced the pc7 board and this fixed the problem.
May 06, 2014 | Miller Welding Tools
I have a miller xmt 304 i bought it used. i have a 12vs wire feeder on it and im not getting power to it. any suggestions on what the problem could be
Hi:
Ok, let troubleshoot this one.
There is only two connectors on your 12VS wire feeder; the lead cable that goes to the + side of the XMT welding machine and the VS cable (Volt Sensing) that goes to you work piece joining the ground cable (don't forget the ground clamp).
a) The mode switch on your XMT must be on V-sense feeder.
b) Your 12VS feeder depending on what kind of wire you are using (innershield) negative side or gas wire + side.
That's it. If there i no spark, there is something wrong with your XMT.
If this was useful to you please vote. Thanks.
Apr 01, 2011 | Welding Tools
I have a Mastercraft AC-230 welder (58-8009-8) with helmits and accessories for sale. It is quite old and user has passed away. How much can I ask for this??
It is impossible to give a price without seeing the lot for sale, I will say that AC Oil cooled sets are a shop luxury and Manufactures of fertilizer would give you a good price, find a friend in the welding game, get his advice,
Jan 27, 2010 | Miller Electric Mfg Co 903505 Invision...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
Need to know on the 14 pin connector what color wire goes to what pin on a miller s-22p12 remote
I would go to www.millerwelds.com and download the owners manual based on your serial number. It will insure you get the correct wiring diagram for your feeder.
Aug 21, 2009 | Miller Welding Tools
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Mastercraft arc welder
i have a mastercraft welder wire feed , the power turns on the wire feed works and the fan in side turns on but it will not weld not even a spark! can anyone help?
Aug 30, 2008 | Miller Electric Mfg Co 903505 Invision...
Welding Tools Logo
338 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
