Question about Evga (131-K8-NF44-AX) Motherboard
No sound evga 133-k8-nf41-xx mainboard where can i get driver download for this?
    Scholar:
  • 58 Answers
Here you will find the drivers:
http://www.evga.com/support/drivers/default.asp?switch=2
The following drivers/files are available for your hardware and operating system combination.
Note: If you are having difficulties downloading the driver file, please make sure you completely disable any third party download managers.
Driver Version : 15.17 - EVGA Recommended Download Auto Installer : YES WHQL Certified : YES Driver File : 15.23_nforce_winxp32_international_whql.exe Notes : NONE << Select a different driver
Posted on Jan 06, 2009
  • Gerhard Stoll
    Gerhard Stoll Jan 06, 2009
  • Gerhard Stoll
    here infos about the board:
    http://www.dealtime.com/xPF-Evga-EVGA-13...
    MPN 133K8NF41AX
    Key Features
    Form Factor What is "Form Factor"?
    ATX
    Compatibility PC
    Chipset What is "Chipset"?
    NVIDIA nForce4 SLI
    Compatible Processors AMD Athlon 64
    Front Side Bus Speed 1000 MHz
    Technical Features
    Integrated Input/Output Ports USB 2.0 x 4 • Serial Port x 2 • PS/2 Mouse x 1 • PS/2 Keyboard x 1 • Parallel Port (ECP/EPP/SPP) x 1 • Floppy Port x 1
    Expansion Slots What is "Expansion Slots"?
    PCI Express x16 x 2 • PCI x 3
    RAID Support SATA RAID 0 • SATA RAID 1 • SATA RAID 0+1
    Storage Controller Type(s) DMA/ATA-133 (Ultra) x 2, Serial ATA II x 4
    Processor
    Socket Type What is "Socket Type"?
    Socket 939
    Max supported CPUs qty 1
    Memory
    Memory Type What is "Memory Type"?
    DDR SDRAM
    Number of Memory Slots 4 x 184 Pin DIMMs
    Supported RAM speeds 400 MHz • 333 MHz • 266 MHz
    Max Supported RAM What is "Max Supported RAM"?
    4 GB
    Audio / Video
    Audio Output What is "Audio Output"?
    Sound Card • 7.1 Channels • Line Out
    Integrated Audio AC97 Audio Codec
    Audio Input Microphone Jack • 1 x Line In
    Video Interface What is "Video Interface"?
    Dual PCI Express x16
    Communication
    Networking Type Ethernet, Gigabit Ethernet, Fast Ethernet
    Other Features
    Other Features Dual Channel Memory Architecture • 64bit Ready
    Chassis Type What is "Chassis Type"?
    Desktop
    Package Qty 1
    Dimensions
    Depth 9.75 in.
    Width 12 in.
    Miscellaneous
    Release Date July, 2005
Network card driver
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver if you see a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver could be on the motherboard disk or the one supplied by your ISP internet service supplier or you might need to download it
Cnetdownload.com
on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109025.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-pro-100-m/3000-2112_4-109029.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109002.html
http://download.cnet.com/%7Bvalue=http://www.download.com/network-3c905c-txm-ethernet/3000-2112_4-109004.html
hope one of these will help
Aug 06, 2011 | Evga 133-K8-NF41-AX Motherboard
I reinstall O.S. Windows XP Home, need the all driver!!! were i can find for the mb EVGA 131-k8-nf44 Tanks Enzo agostino
Go to:http://www.nvidia.com/Download/index.aspx?lang=en-us
Select: Legacy> Nforce 4 series > nforce 4 SLI AMD > then select your OS and Language.
Then download the drivers.
Here is the updated BIOS too ftp://ftp.evga.com/BIOS/NF41_E61.exe
Hope this helps.
Jul 22, 2011 | Evga (131-K8-NF44-AX) Motherboard
I need drivers for Evga motherboard 112-ck-nf75-k1. I can't find them on Evga website. Please help.
Click on the link below, and select Mainboard fron the left hand side, then select Evga 730i/730a/630i/610i from the middle and then your operating system from the right hand side.
Your board is the 630i model
Regards.
Dec 14, 2010 | Evga (131-K8-NF44-AX) Motherboard
Computer will not boot.....power button lights & fans for a second or two....FF displays on debug....and all goes dark?? is it the motherboard?? or something else?
probably a faulty lead
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 18, 2010 | Evga 133-K8-NF41-AX Motherboard
Can only seem to get 100mb between system and LAN 1000mb switch. Found what I thought was updated network drivers for Evga 133-K8-NF41-AX Motherboard however, I still dont see 1000mb speed in properties...
even if the switch is capable of doing 1000 the network card must also be able to handle the speed and from what you are saying it is not capable of 1000 only 100
May 09, 2010 | Evga 133-K8-NF41-AX Motherboard
I have a EVGA 133-K8-NF41 mobo and want to update my BIOS but can't find what the latest would be and the flash utility for it. can you help?
forum topic: http://www.evga.com/forums/tm.aspx?high=&m=63702&mpage=1#65116
direct link to bios: ftp://ftp.evga.com/BIOS/NF41_E61.exe
Feb 25, 2010 | Evga 133-K8-NF41-AX Motherboard
Need driver for EVGA 133-K8-NF41. Anyone know a good link?
You can download the nforce4 chipset drivers directly from nvidia.
http://www.nvidia.com/object/nforce_nf4_winxp_6.39
I had the same mobo, same problem and this worked fine.
Feb 22, 2009 | Evga 133-K8-NF41-AX Motherboard
Evga (131-K8-NF44-AX) Motherboard Logo
362 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
