Question about Coby DVD-937 5.1 Channel DVD Player/Receiver Home Theater Speaker System System
Coby dvd player
My coby dvd player disk is stuck in the player and the door will not open. What should I do.
Open the cabinet by removing all eight screws, locate the two screws holding down the top of the dvd drive and remove them. Slide back the plate and lift and you will be able to remove the disc from the drive.
Posted on Oct 16, 2008
Hit it
Posted on Mar 23, 2008
Fix a stuck disk compartment door on a Philips DVD player
Hope this helps: https://www.youtube.com/watch?v=sa96VVH8z4I
Jan 01, 2015 | Philips Bdp3380/05 3D Blu-Ray Disc And Dvd...
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
I have 2 dvd players that have gone out on me this week. One does not read the disk and the other door won't open. Is there a lens cleaner for dvds that might work:
The Coby 224 is a bottom of the line "piece of cheap Chinese crud". No offense, but this is a DVD player that costs more to ship it over here than it does to manufacture the product. Purchase something a bit more substantial for continued dvd viewing.
Feb 27, 2009 | Coby DVD-224 DVD Player
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Not repsonding when closed
Every time I close my Coby TFDVD5000 Portable DVD Player I whait untill it is finished loading but then it says no disk. I took the back off to look at it, and I noticed that each time i close it the disk will spin untill the lens starts reading the disk. The problems started when i put a disk cleaner in, and i gess the lens was not dirty. Can you help me?
Jun 07, 2008 | Coby TFDVD5000 Portable DVD Player
Problem with Coby DVD player
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "wrong disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 01, 2008 | Coby DVD-209
DVD starts to load but does not play.
Not sure if anyone found this solution, worked for me.
1. Press SETUP
2. Press FFW, F REW, NEXT, PREVIOUS
3. Change the code to 255 using the RIGHT arrow key
This will unlock the DVD player for all regions.
Jan 26, 2007 | Coby TFDVD5000 Portable DVD Player
372 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Marvin
Marvin
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
