Question about Zebra 105SL Thermal Label Printer
  • joannadingle Feb 27, 2009
    Just happened today. :( Calibrated, but first couple of labels good, then slips off. Am wondering if the label sensors are dirty. Will try, and if find a result, will post.
    Problem Solver:
  • 5 Answers
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Posted on Mar 27, 2009
  • smlwrld Aug 02, 2011
    The problem for me was not the Ribbon Take-up Spindle, but the Ribbon Feed Spindle (I assume). If there is no tension on that spindle the feed ribbon will sag and feed out of alignment. I removed the clip at the end of the spindle (careful not to lose internal spring) and noticed that the spring inside had slipped out of it's hole that holds it in place. I placed it back correctly and found that, with the correct tension, the ribbon didn't sag and fed correctly.
  • 21 Answers
Check your default label size under printer preferences. It must be set for each user.
Posted on Jun 21, 2014
    Problem Solver:
I forgot to change the media setting from continuous to websensing.
Posted on Apr 11, 2009
The zebra 105s printer wont line up the labels and i dont have a user guide
Posted on Apr 01, 2009
My zebra tlp 2824 won't line up to the labels
Either your printer needs calibrated: Calibrate Zebra Desktop Printer
Or your label template size( in the software) does not match the label size. I recommend the calibration then looking at the software label templates.
Jan 20, 2014 | Zebra Eltron LP 2824 Thermal Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
We are using the Zebra 170XilllPlus printer for printing rolls of labels which they have some preprinted portions on them. However, after we printed the first label of a roll successfully the next and all...
Make sure the pause light is on and press calibrate. See if this calibration solves the problem. If not align the media sensors (top and bottom) to a position that is aligned with the least amount of preprinted data and calibrate again. Print configuration Power on while holding cancel key for 10 seconds. Use the config to help troubleshoot. Make sure the sensor type matches the media. Download user manual at
Nov 04, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Label for zebra tlp 28844-z with 2 columns not aligned
I'm not sure what you mean here but I'm guessing that you mean the labels are not advancing properly meaning the print is not aligned vertically on the labels. If that is the case, two possibilities:
1. The printer just did not get a good calibration on the printer. You can force a calibration by turning off the printer, pressing and holding on the FEED key while turning the printer on. Keep pressing until the status light flashes once, then let go of the FEED key. The printer will calibrate for the label size.
2. If the calibration sequence does not correct the issue, then it's possible that the gap (horziontal) between the labels just happens to be over the media sensor which is located in the middle of the 4" print width area. If that is true then the labels will never calibrate.
Hope that helps !
Apr 16, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My Zebra LP 2844 printer is not aligned and the info on the tag prints onto the next tag, how do I fix this?
Calibrate the media that is in the printer. Power the printer on while holding the feed key. When it flashed red, let go. It will calibrate, print a config label, then go into dump. Press the feed key again to exit dump. Once this is complete, your printer should advance only one label at a time when you press the feed key. If this is working as expected, but the labels are not printing right when you print from you application, there is a problem with your format or driver settings.
Jan 07, 2010 | Zebra S4M Thermal Label Printer
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Nov 12, 2009 | Zebra TLP 2824 Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
Cannot set label length
Performing, Setting, and Troubleshooting Calibration Issues
This solution is useful for
  • Calibration: consistent positioning of the label and the print
Symptoms addressed by this solution include
  • Prints, then skips a label
  • Print is overlapping onto next label
  • Paper out error is occurring
  • Print position is drifting up and down on the labels
  • Labels stopping in random locations
Perform a manual calibration:
Z4m + sensors
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Zebra Z4M+ Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
May 13, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
564 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
