Home | Bosch | 24 in. SHU66C05 Stainless Steel Built-in Dis... | My dishwasher does not...
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Problem for Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
My dishwasher does not fill
By gayleau1 on Mar 31, 2007
Hello, Just last night my Bosch dishwasher decided to let me down. It has been the best machine for the last four years; washes perfectly and quietly. Lat night I went out and left it doing the dishes for me as I always do. When I got home the electronic timer was sitting on 1 minute, there was no water in the machine, the soap block was undissolved in the bottom of the machine, and the motor was still humming. I turned it off at the wall, waited a while, then turned it back on hoping to reset the timer. It started at 38 instead of 88 and no water pumped in. I presumed from this that it is the solanoid (or fill valve) which is actually inline, right on the faucet, instead of in the machine like all the older machines I have had. Unfortunately it is a very expensive assembly and I do not want to order one in just to find it does not fix the problem. I wonder if anyone else has had the same problem, and if so, what they did to fix it. Or if anyone has any suggestions as to what else might be the problem.
Comments:
Mar 31, 2007
- Fantastic. Thanks for such a quick reply. I will give it a go tomorrow (rushing out now) and let you know.
Same Problem
Apr 10, 2009
-   After the dishes were cleaned we noticed the dishwasher was filling up with water even though its off and the door is open. We pressed rinse and hold to drain and it worked. Now we're ready to start the wash and it just hums and no water enters the washer.-   leipprandt
Best Solution
posted on Mar 31, 2007
Very Helpful)
tresilla
Rank: Guru  Bosch Expert
Rating: 87%, 1584 votes
suspect it has not drained fully hence will not fill. humming noise may be a foreign object stuck in the pump impellor. take pump out and check impellor turns freely
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU66C05
Questions and Unsolved Problems for Bosch 24 in. SHU66C05
Do you recommend Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher?
Answer
Answer
I found that by initially disconnecting the pipes and cleaning them out (without the usual... (More)
Answer
our bosch dishwasher had some water on the floor . I think it's coming from the bottom seal of the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C05...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
