Question about Daewoo DSP4210GM 42 in. Plasma Television
Plasma tv only 18mts old has appeared with 3 green lines down the screen
This TV was bought about 18mts ago, and hasnt really had many hours of viewing... and it has started to appear with annoying green lines down the left had side of the screen. Do you know what the damage is ? what are my options Many thanks Keith
  • Keith Bell Apr 20, 2007
    thanks for that.. the warranty was only for a year - i will follow up on the driver board. hopefully its not the plasma panel.
    President:
  • 1,284 Answers
I would check and see what the warranty is on this unit. It is either going to be a driver board issue such as a bad connection or a bad board itself. The other and most expensive issue could be the plasma panel itself which usually cost more than the set did originally.
Posted on Apr 16, 2007
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
LG Plasma TV MOdel 50PC5DC
You will definately want to call LG and have them refer you to an auth. service center for warranty repair. This is either a failed scan bd or mayber even a bad plasma panel and there is nothing simple for a problem as you describe.
Apr 08, 2008 | LG 42PC3D 42 in. Plasma Television
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
Samsung 50" hdtv; picture going dark along a sharply demarcated band on screen
This really shouldn't be the normal life of the lamp inside your TV...plasmas are meant to last at least one full year, up to three depending on how many hours per day they are used (I'm sure you can figure out where on that scale your tv lies). It could be caused by magnetic field interference, most likely from a speaker sitting too close to the tv. The magnetic field that is produced by the speaker refocuses the color on the tv, causing dark spots; they can sometimes appear as red or purple tinted areas as well. Most of today's tv's (especially plasmas) and speakers are set up so as not to do this, however you can never really be positive that it will not happen. If you have speakers near your tv, move them at least a two feet away, but the farther the better. Unfortunately, there is no real fix for this problem unless you take the tv to a professional and see if they can de-magnetize that section of the tv. I hope this helps some...if you don't have speakers near your tv then I apologize for wasting your time! haha, at least you'll know for future reference though. Your best bet anyway is to return the tv back to where you bought it or call the manufacturer; if it's only 6-7 monthes old, it should still be under warranty. Good luck!!
Mar 10, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Daewoo DSP4210GM 42 in. Plasma Television Logo
172 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
