Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Natural Gas Pack: Smell & Soot on exhaust tube
The heater works just fine, heats well. CO detectors (nightHawk Digital) all read 0ppm. Noticed a pungent odor outside when heat is on and there is a brown coating on aluminum exhaust vent tube. This tells me the gas may not be burning completely and perhaps increasing my heating bills. I want to open the unit to check for air inlet restrictions & clean whatever may be dirty & interfering with the air/gas mixture.
The gas pack is beside the house and easy to access, top comes off easily.
Looking for pointers on what to expect & procedures for this service.?
THank you
  • CajunWon Dec 19, 2008
    I was able to look at the unit. turned on and the flame going into the heat exchange pipes as nice and blue and appeared to have an unobstructed flow into the exchanger. Looking into the vent with flashlight, no obvious obstruction. The heat exchanger is 'U' pipes. The outer pipe is twice the diameter of the inner pipe. The inner pipe has significant dimples, guess to increase surface area. But inside the dimple have obvious corrosion and even holes that appear almost like intentional narrow slots. These hole/slots are only on the lower portion just before the exhaust exits the unit.
    So is this inner/smaller pipe supposed to have these holes/slots?
    excuse my bad drawing here.
  • CajunWon Dec 21, 2008
    Quick search at expertappliance.com/carrier-heating.html shows a Heat Exchanger for Carrier 48SX at $578, about 5x more than I was thinking. Considering a repair/patch of this issue. Steel wool to remove surface corrosion, assuming this is rust so use a rust converter on surface to prep area. Apply JBWeld 500* to patch. These small holes are within 18" of the exhaust vent, assuming the pipe temps are less than 500*F by this point.
    If this resolves the exhaust smell & lite soot, then I've isolated the issue. After heating season remove exchanger, take to welder and let them suggest solution, perhaps to bronze/braise these small holes.
    Critique welcome
  • 1,420 Answers
Time for a good cleaning. Make sure the heat exchanger is in good shape and is getting good heat flow over it to the exhaust. The odor may be an indication of a restriction in the heat exchanger, the flames are hitting something, improper air or gas adjustment or a blower not coming up to correct speed. You can access the heating unit from a side panel. Look for the exhaust port and start with that panel. Wasps nests are predominant in these things.
Posted on Dec 19, 2008
Why does my pilot light keep going out when heating is on ?
Water heater and house heater are sharing the same vent?
Then vent is bad, and heater is pushing combustion by-product down into the water heater and blowing out pilot.
Call technician immediately to avoid CO poisoning.
Look for black soot on top of water heater... test the vent:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#vent
Read about Carbon Monoxide poisoning: symptoms and first aid
http://waterheatertimer.org/Is-natural-gas-clean-burning.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 08, 2014 | Water Heaters
I have a Goodman gas (propane) pack heat pump which was installed a month ago on our new home. There is a horrible smell coming from around the unit, and some soot is on the propane pipe just in front of...
Please SHUT IT DOWN !!!!!!!!! Contact the installer because the LP propane conversion kit has probbaly NOT been installed.Any gas system should NEVER make any soot.
Oct 31, 2011 | Goodman GMS90703BXA Heater
Our gas/co2 detector is going off we don't smell propane which is our gas source. the detector emits the word gas
if you have a furnace it could be detecting the exhaust emission. if none of the above then get it recalibrated or buy a new one if its cheap.
Jan 30, 2011 | Kidde Nighthawk Combo Gas/co Detector
How long does the nighthawk model carbon monoxide detector last for.
I had 2 and they both did the ERR thing and stopped working within a week of each other and that was about 7 years.
Nov 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
I have a NIGHTHAWK CO2 DETTECTOR, it reads ERR & i dont know what it mean?
Should be a Carbon Monoxide detector (CO). The ERR display means the CO sensor is probably shot. Unlike most smoke detectors, CO monitors have a limited life span. Same thing happened to me and had to get a new one.
Oct 18, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk Combo Gas/co Detector: is 218 a high read of carbon monoxide levels in a ...
A reading of 218 should be treated as an emergency. When a Carbon Monoxide level reaches over 70 ppm, you should have a professional inspect and repair the appliance that is causing this issue.
Carbon monoxide levels above 70 ppm will cause headache, fatigue and nausea. Levels above 150 ppm can cause serious injury or death.
Read section 5 US Consumer Product Safety Commission.
May 17, 2010 | Kidde Nighthawk Combo Gas/co Detector
What does code 222 and 224 mean on the kidde nighthawk combo gas/co detector?
was there also an alarm with that reading? Normally it would suggest gas leak.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 03, 2010 | Kidde Nighthawk Combo Gas/co Detector
Goes off saying gas but no apparent gas smell ?
Co2 detectors do have a life span of about 2 years and keep in mind that carbon monoxide does NOT have a smell, thus the point of the detector.
I would do a test, most of these units have a test feature. Then unplug and remove battery, then plug back in.
Mar 08, 2010 | Kidde Nighthawk Combo Gas/co Detector
Gas alarm keeps going off. No smell of natural gas in the house. It has happened 3 times before in the last month. It then shows number 210. What does this mean?
Depending where it was installed your sensor in the unit may be dirty. Try to vacume or blow air into the sensor this may help. If it dosen't toss it and buy a new one. please check your instructions carefully as to where it should be installed.
Apr 22, 2009 | Kidde Nighthawk Combo Gas/co Detector
Carbon monoxide is on
When a Carbon Monoxide Detector alarm goes off, you should follow the procedures that came with the manufacturer manual. Even when the alarm sounds, you cannot smell, taste, or see this dangerous silent killer known as Carbon Monoxide.
Have your house checked by your local fire department for possible levels of CO gas readings. If this all checks out, you can go online to Kidde Nighthawk website and find the manual for your Carbon Monoxide detector model.
Hopefully, you found your solution since you posted this question back in Dec, 2008. Go to my website to read industry information and to view most Brands and Models of Carbon Monoxide Detectors.
Dec 16, 2008 | Kidde Nighthawk Combo Gas/co Detector
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
667 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
