Question about E-Machines eMachines Desktop PC
Memory stick reader
I place a memory stick (sandisk) in the slot and all i get is the green
light. it stays constantly lit and i get no indication that there is a stick in
the slot, other than the green light. I have tried numerous sticks that i
know are good with the same result. also, when i place the stick in the
slot, it doesn't "feel" like a solid fit. i know i am placing it in the slot correctly. HELP
  • jonracs Dec 20, 2008
    tried blowing it out, no luck - thanks to the effort. i may have to replace the reader.
  • Dan rogers
    Dan rogers May 11, 2010
    when you open my computer after you insert the drive does anything show up as "removable memory"?
    Problem Solver:
  • 6 Answers
It sounds like to me that either the slot is damaged, dirty or you may have the wrong kind of media for that slot. If you have a can of dust off (compressed air) you may want to blow out the dust in the slot. After doing this, try your memory stick again. If it still doesn't work but it has in the past for that slot you may want to consider replacing the card reader. Sometimes the pins get dislodged or bent inside. Good luck, let me know how it turns out. Thanks...
Posted on Dec 19, 2008
When I put my memory stick pro duo (SanDisk) into the slot, it doesn't appear on my computer
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jul 20, 2012 | SanDisk Electronics - Others
I have put my m2 memory card in memory reader then plug the memory reader in usb slot at my pc ( windows 7 os ) but it says system cant install driver for this . and when i gio to device manager there is a...
Check it in other computers. If it works welll then you have install driver in your system. Although now a days drivers comes automatically installed, sometimes it causes problem. Or you can go to sandisk site and get the driver.
Sep 17, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
Unable to read my memory card, it seem to be memory slot problem
i need to open my SanDisk M2 memory card, but my card reader is unable to read it. please help. there are important files on this memory card. thanks in advance..
Oct 19, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Pleeze help, ok i insert my memory card reader and computer recognises, fine, however when i insert my 16gb sandisk m2 memory card.....nada, nothing, zilch!?? It says that there is no media inserted and...
This is because there is a fault in the slot where you put the memory card.
The problem is the memory card contact surface in not in contact with the memory card reader contact surfcae.
So please change the memory card reader it wil be fine.
Thanx
Jul 08, 2010 | SanDisk 1GB Memory Stick M2 Memory Card
Card Cant Be Read
Same thing happened to me, after taking some pictures of a christening, connected to card reader, it wasn't recognised by card reader. I re-inserted it in camera and got card error, tried some softwares to extract pics but for nothing!!! I'm very dissatasfied!!
May 25, 2010 | SanDisk Ultra II 8GB Secure Digital High...
I have a sandisc memory stick pro duo 4gb and it is too small to fit in the memory card slot of my laptop which is an acer aspire 7220 series. please help x
Hi there!
Simply insert the card in it's adapter, then insert it into the memory slot.
However you can buy yourself an external USB card Reader supporting your pro duo card.
Please rate this advice as it's very important for us.
Good luck friend!
Mar 13, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
Dec 24, 2009 | eMachines ET1810-01 PC Desktop
Not recognizing memory card in slot
are you sure you are sticking it in the correct slot for your memory card and you are not sticking it in backwards/ upside down
also this memory card works in your cammera still correct?
Mar 31, 2009 | HP DeskJet 5650 InkJet Printer
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Problem with memory stick micro m2
is the card being read on the other device like camera/mobile etc.
if yes than card is okay
its the pc which is not compatible with your card. in this case u cannot do much but buy a card reader costing 5 usd
Apr 27, 2008 | SanDisk Memory Media
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
