Question about Sharp AL 1631 Copier
LEAVES A BLANK LINE DOWN THE COPY
THE COPIES HAVE A BLANK LINE ABOUT 1/2 INCH WIDE ON LEFT SIDE ON ALL COPIES I MAKE...CLEANING DOESNT HELP....
  • Tim Babcock
    Tim Babcock May 11, 2010
    This is a blank line and not a black line?
  • Vladimir Machlis
    Vladimir Machlis May 11, 2010
    Is the line completely blank or just faded?
    In any event, try to clean a Transfer Corona wire (you'll find it on the side door inside the metal casing) with a green wire cleaner you will find inside the side opening of the copier when you open the side. Just be careful - the wire is hardly visible (60 micron in diameter). Don't press too hard, just slide the cleaner front to rear and back.
    If you still have the User Manual, you'll find instructions and pics there. Good luck.
    President:
  • Sharp Master
  • 990 Answers
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Posted on Dec 20, 2008
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
1/2 inch wide black line appears on the copies
Please use the link provided below to download the user guide. The user guide and the troubleshooting guide will have detailed steps to solve this issue.
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PSC%201510-_E
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
WHEN YOU SEND A FAX IT LEAVES A LINE HALF INCH BLANK DOWN THE RIG
Does it also leave the line when you make a copy? Lift the lid and make a copy cover up. If it is there on the copy then most likely your scanner needs to be cleaned. If it isnt there when you copy, let me know we will go from there.
Dec 08, 2008 | Xerox WorkCentre M15i Laser Printer
Workcenter xd103f copy comes out blank
Which cartridge did you change? If its the toner cartridge, make sure none of the packaging materal is left on it, same with the drum cartridge. First and simply remove and reseat the cartridges.
What I suspect with the blank copies is a broken transfer corotron wire.
Open the right side door. On the bottom you will see some whit plastic rollers. Above that you will see an opening about 1/2 inch wide. There is a very thin wire in that channel. That wire has probably broken causing your blank copies, I highly suspect that is broken.. That wire when it is dirty also causes really poor copy quality.
Also clean all the mirrors and glass well. That will cause poor copy quaility issues.
Mar 12, 2008 | Xerox WorkCentre XD103F All-In-One Laser...
Leaves about a 1/4 inch space down middle of paper.
That is the cleaning assembly in the drum cartridge.Either something slipped into the cartridge or the blade tucked. Sounds more like something is in the cartridge blocking the drum from both cleaning and charging/
Mar 05, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
266 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
