Question about JVC AV-36950 TV
Tv won't turn on red light comes on goes right back off with clic
Turned the tv off went to work came home tv won't turn back on red light comes on goes right back off and makes the clicking noise it usually makes when it comes on I checked the little fuse inside and it looks ok.
  • Archie Ferguson Dec 29, 2008
    turned the tv off went to work came home tv won't turn back on red light comes on goes right back off and makes the clicking noise it usually makes when it comes on I checked the little fuse inside and it looks ok. I tried unplugging it over night still does the same thing.
    President:
  • 2,110 Answers
If you had removed the back off the set with it unplugged and asked
what is the black thing with the big red wire going to the top of the
tube because it has a big hole in it, then we could have guessed what
part had failed but still no way to know how far the damage went into
the electronics. You would need to have someone troubleshoot the set
who knows how to repair electronics.
Posted on Dec 29, 2008
  • Sibananda Jena
    Sibananda Jena Dec 29, 2008
    I dont know how much technical expirence
    you have, but be very careful there are many circuits that have high
    voltage on them, even when off, and these voltages can be lethal,
    especially any thing that is connected directly to the A.C. line [such
    as the primary of the power supply]. most of the rest of the set is
    isolated from the A.C. line. so be careful. now for the tecnical part,
    most common is a failure of the vertical circuit, the shorted IC will
    cause the set not to come on in order to protect the power supply.
    after you replace the IC and any resistors and diodes that may have
    failed as a result of the bad IC, change any caps related to the
    vertical circuit, they will be 100, 220, or 47 mfd @ 35 volts or so.
    lastly check the zener diode that is connected across the output of the
    IC for leakage or shorts. It is also possible for a filter cap. in one
    of the low voltage supplies to be open [it may be noticed as it will be
    pregnant.]to cause a no operation condition. so good luck and think
    safety.
  • 916 Answers
Do a full reset it can take 2 to 4 hours all you need to do is unplug your tv for that amount of time. It has entered protection mode. Doing this will reset it.
Posted on Dec 21, 2008
  • JVC Master
  • 19,396 Answers
If the red light comes on goes right back off and makes the clicking noisethat means that the TV entered in protection mode.
Protection is a special diagnostic mode, that starts when a fault is detected, the clicking noise is a safety switck that keep turning off TV to prevent further damage.
Try unplugging power cord for one or two hours, if this does not work, then the TV must be tested anby a technician and fixed.
  • Ginko
    Ginko Dec 21, 2008
    Common reasons for protections are : alignment fault, blown component, short, cold solder joint, PSU problem (power caps blown), Convergence problem (STK IC blown).
    For all this problems you need an experienced technician, try first unplugging the TV for a while, as you have had this problem for a while and things are getting worse.
    It may be time to replace your TV.
  • Ginko
    Ginko Dec 29, 2008
    If the TV stays on protection after leaving it unplugged for a long time, that means that there is an internal fault.
    The technician will start inspecting and testing the psu board, looking for shorts, faulty capacitors and other possible faults, and then will proceed in testing deflection circuits, convergence and other common faults.
    If the TV model is the CRT descripted on title, it may be better to buy a new TV, rather than spending $100 or more to repair it.
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
I have a 3year old Sharp TV. It won't turn on like it should. I turn it on and the red light goes out and it stays out. Then it comes on again. I turn it on and the red light goes out. If I am luc
Power supply or something in the set not allowing supply to come up, not likely to be a do it yourself repair---consider having a tech or a shop look at the set.
Aug 31, 2012 | Sharp LC42SB45U 42 in. LCD TV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
JVC AV-36950 TV Logo
128 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
