Question about D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point
DWL 2700 AP power light flashing, no IP
I opened the unit, noticed a possible serial and JTAG connection. Is there away I can bring this unit back to life??
  • 26 Answers
Yeah, not a good idea to have opened it if there is a warranty still in effect. Belkin, DLink, and Linksys are all made by the same corporation, Cisco, and generally a flashing power light indicates a fault condition. You may be better off getting a new one.
Posted on Dec 19, 2008
Cant open the admin console on mt dwl-3200ap
Try this. Push and hold in the rest button while at the same time pull out the powers supply line from the unit. Release the reset and wait 30 seconds. Push in and hold in the reset button, apply power to the unit and keep holding the rest button in for 30 seconds, then let the reset go. It should reset everything back to factory settings and hopefully let you in with the original admin pw when you bought it.
Aug 01, 2014 | D-Link Computers & Internet
TALKING ABOUT THE ACCESSING THE IP ADDRESS ON THE DWL-2000A,I DON'T THINK I UNDERSTAND THE SOLUTION TO THE CONNECTION BECOS THERE IS ONLY ONE LAN PORT ON THE AP WHICH ONE CAN CONNECT TO THE MODEM. SO IF...
To connect the AP directly to your PC you sould need a "crossed" LAN cable.
On you PC you need to set a IP Address of the same subnet of DWL-2000AP (defaul IP is 192.168.0.50) like 192.168.0.xxx
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and select "Internet Protocol (TCP/IP)", click properties, now set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Confim clicking OK OK OK...
Now you can access you devices tipyng http://192.168.0.50 on your prefered browser. Default login is "admin" as username and empty password.
Let me upate.
Sep 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
DWL-2700AP reset default settings
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
Jul 18, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
DLINK DWL-2100AP
check whether DHCP is enable on ur main AP.
Apr 21, 2009 | Computers & Internet
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point Logo
519 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
