Question about British Telecom Synergy 2110 Cordless Phone
BT Synergy 2150 Cordless Phone
I have a base station and 1 extra handset. I have a continuous flashing new call icon on the display panel, and the "In Use" green light flashes continuously on the base station. I have done factory reset of the phone but this does not resolve the problem. I have a user guide but it does not mention anything regarding this problem. I look forward to receiving your response and possible solution.
  • 3 more comments
  • Anonymous Nov 20, 2007
    New Call is permantly displayed and the In Use light flashing. Have reset and also put new battery in, but doesnt solve anything.
  • briern Nov 27, 2007
    my 2150 flicks from in use to power. both lights flick on and off continuously? I have put changed the battery from another station that is working - in but it is still happening
  • jpeters628 Jul 28, 2008
    same problem - had it about a year and none of the four phones work anymore - they quit one by one. Searches for base and cant make or receive calls. Started by having short range - would beep if I entered the next room with it. Then stopped completely. TERRIBLE PHONE. Wish I knew before.
  • anneb312 Dec 22, 2008
    I have tried the above but it will not let me into the options under caller id
  • Anonymous Mar 15, 2014
    ican receive calls and when i plug in my old bt phone it works sa normal
As far as I can understand your problem, there is nothing wrong, just view the new calls ( options/caller id/options/view/ up and down arrows to scroll through caller id's). New calls message will then disappear, although it doesn't really matter if you don't do any of this.
Posted on May 15, 2007
  • p_harman Dec 21, 2010
    There is a problem here, when this happens pressing the option button just returns to the 'New Call' display - it is not possible to view the calls. Paging works OK but that is just about it. This is a base problem not a handset problem and factory reset on the base does not appear to work either - handsets remain registered.
Try opening handset and disconnecting the battery, then reconnect, This worked for me..
Posted on Jul 07, 2009
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
Mar 24, 2014 | Binatone Lifestyle 1910 Twin Cordless...
I have a Eurotel E1110 device but it is asking me to register the third phone again. I do not know the pin-number so what can I do?
7.5 Registration
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Jun 11, 2010 | Lands Phones
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Can't register new handsets
with in this time.
Hope this helps you
Apr 10, 2009 | Lands Phones
My handset displays "New Voice Mail" and the base displays 00.
This is the problem, thebase charge light flashes continuously,It says that I have a new voise mail and the the base says (00)
Mar 04, 2009 | Uniden Cordless Phone
How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Dec 10, 2008 | Motorola Mobility MD41 Expandable Handset...
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Getting a new mobile in the registration mode with my Gigaset 8825 base station.
    You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
    Oct 18, 2007 | Siemens Gigaset 8825 Cordless Phone
    Blinking lights
    The blinking cordless handset seems to be your main issue. IT should not continue to blink after a start up. I think if you replace the handset and sync it to your base station, your problem will be resolved. The T7406 phones are not the most rugged handsets. IF this unit was dropped, a lo of your symptoms make sense.
    Jan 15, 2007 | NorStar T7406 Cordless Phone
    Doesn't anyone have an answer or some help? Please!!!!
    Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
    Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
    British Telecom Synergy 2110 Cordless Phone Logo
    1,096 people viewed this question
    Top British Telecom Lands Phones Experts
    honeybun1986
    David Burbee
    David Burbee
    Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
