Question about AT&T 5965 Cordless Phone
Invalid Base ID message
We have had an AT&T E5965C phone system with one handset for several years. It had been working fine but now the handset says "Still searching for base". We have tried the following:
1. Reset the system using the instructions provided by AT&T - take out batteries, power off for 30 seconds, etc.
2. Replaced the reachargeable batteries in the handset.
3. Re-entered the base ID, at which point we get the message "Invalid Base ID". And yet this same combination of base and handset worked until recently.
Can you help? Or does anyone know how to get to a real person at AT&T support?
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Posted on Sep 17, 2007
SOURCE: Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Posted on Feb 29, 2008
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Posted on May 30, 2008
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
I get Warning! use rechargeable batteries only. But they r rechareable, and changing them doesn't help
Reboot the base :
-Make sure the handset is HF and not on the base.
-Disconnect the base from the power supply and remove the batteries (only the base's, don't remove the handset:s batteries), soon, after a few seconds at most, the handset not finding the base when scanning for it, should go off by itself.
-Wait a moment (60 sec should be plenty) then reverse the last step (batteries+power-supply).
When reboot is completed (watch for the normal screen on the LED display) just put the handset back on the base again, 'voila' !
Sep 04, 2011 | AT&T E5965C Cordless Phone
"Extension in Use"
I found the solution accidentally. I just unplugged the phone from the jack and plugged it back in, and that did the trick.
Jan 06, 2010 | AT&T 1719 Digital Answering Machine
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
I have an EP5962 system with 4 cordless phones. It is at a seasonal residence, and I just came here for the first time this season, and none of the handsets works. The base unit works. I charged for 24...
First thing you must do, is clear the base memory of the phones.
To deregister all handsets:
Select MENU on the base, scroll to SETUP BASE,
then select OK.
Scroll to DEREGISTER ALL and then select SET. Thebase will display DO YOU WANT TO DEREGISTER ALL HANDSETS?
Select YES. All handsets are deregistered and are unusable until each has been re-registered
During registration,you must enter the 15-digit ID number of the telephone base. To find this number, go to the base, select MENU, scroll down to DISPLAY BASE ID, then select OK
Jun 27, 2009 | Lands Phones
Caller ID has aparently stopped working
Based on a user's review of this phone system on Amazon, I unplugged the base station, waited a few seconds and then plugged it back in. Caller ID display and announcement both work fine.
Mar 23, 2009 | Panasonic KX-TG5777 Cordless Phone
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Dect 1221
On you base between Clear and intercon push middle button, with erow push display base -ID
Apr 07, 2008 | AT&T E5965C Cordless Phone
Handset can't find base.
I just got a 3rd handset for the same phone system and were having the same error message,,, the at&t help line does not know what it is,.,. We returned it once and got another one because of the same problems, and were still having it.. AT & T help line said to return it again and try another one .. then he actually said to replace the whole phone system .. thats easier said than done! we paid 199 plus tax on the system and then another 81.00 for the third handset!
Nov 20, 2007 | Office Depot Ativa D5772 Phone
AT&T 5965 Cordless Phone Logo
55 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
