Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
The wheel on my sons Ford Mustang stopped working
    Scholar:
  • 50 Answers
Http://www.toyservice.ms/Search.aspx?sq=mustang go to this link and select your model number... you should be able to order the part to fix it with no problems... good luck
please rate if this helps.
Posted on Jan 13, 2009
Engine won't turn over 1988 ford mustang 5.0 eng.
A very common problem with the fords of this era was the negative battery cable connection. The cable has a tendency to loosen up where it is attached to either the frame or engine blck. The other battery cable, the positive one (red), runs very close to the exhaust manifold and pipe down near the starter motor and will sometimes make contact, melt the insulation on the wire and short out. I would recommend examining and either tightening connections or replacing the battery cables.
Apr 30, 2015 | 1988 Ford Mustang
Just purchased this car for my son. The rear end vibrates at speeds over 65 MPH but runs fine at lower speeds. Had tires rotated but they are more than 50% worn.
Again, if the vibration wasn't apparent before the tire rotation, look for a broken belt in the tires, bent rim or perhaps a wheel weight has gone AWOL.
-Steve
Apr 18, 2015 | 2002 Ford Mustang
Working on my son's 2001 Ford Mustang and I had to jump it. The anti-theft alarm is on and now won't start. What do I do?
tow it to the dealer. you need to use the scan tool to reset the security module. requires 2 keys to complete the proccess
Mar 29, 2011 | 2001 Ford Mustang
Steering wheel locked. How do i unlock it?
Try wiggling the steering wheel while turning the key. If that does not work the locking device has broken apart inside the column and will need to be town down to inspect
May 09, 2010 | 2001 Ford Mustang
QUISIERA SABER SI ME PUEDEN INFORMAR COMO PODRIA
Es probable que esta informacion pueda servirte: Ford Mustang
Suerte (recuerda valorar esta ayuda)
Jan 31, 2010 | 1982 Ford Mustang
No headlights or turn signals on my 1988 mustang
Check the turn signal dimmer switch. It is under the steering wheel. You will need to take the steering wheel off. See if any wires are loose or damaged going to the turn signal switch. Good Luck!
Nov 29, 2009 | 1988 Ford Mustang
What is the torque specs for the front wheel bearing/hub assembly nut on a 2002 ford mustang?
Wheel bearing don't have torque specs (to the best of my knowedge). They have a procedure - in this case it is....
1. With everything clean and packed with grease, snug the bearing lock nut until it stops.
2. Reverse it about 1/8th to 1/4 turn and insert the cotter pin.
Done
Oct 11, 2009 | 2002 Ford Mustang
1995 Mustang GT - all
yes! if the neon light were hardwire in that mite be the problem so you sould remove them and look over all the wiring to the lights to make sure thier is no shorts in wiring.
Sep 13, 2009 | 1994 Ford Mustang
Car just stopped working
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Jun 18, 2009 | Fisher Price Power Wheels Kawasaki KFX...
89 ford mustang
Hi
Why not Google..... for a local Mustang Enthusiasts Club ?
Good Luck !
Please give a FixYa Rating Please ....I need to be a Guru !
John.
Feb 04, 2009 | 1989 Ford Mustang
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
134 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
