Question about Norelco Advantage 5615 X Electric Shaver
Doesn't hold a charge or cut very well anymore
I've had my advantage for maybe 10 years. I have never replaced the heads or oiled anything. I just take the head apart and clean it periodically. About a year ago, I started having trouble getting it to cut. Now I need to go over my face again with a straight razor some days. Should I replace the heads? Then a few months ago I noticed it was having trouble maintaining a charge for more than a couple of days. Now I'm lucky if it holds a charge for more than a day. I keep it plugged in all the time now.
  • Norelco Master
  • 1,626 Answers
Heads for your model are no longer available. Shaver will not hold a charge because batteries need replaced. Batteries can be replaced but soldering is required. If you have cleaned it well and it does not cut, I suggest getting a new shaver.
A full line of Philips Norelco shaver can be found at shaveroutlet.com
ShaverOutlet com ShaverOutlet com Rotary Shavers Men Shavers Manufacturer...
Posted on May 24, 2017
5 Suggested Answers
SOURCE: Replace heads light
I have been able to reset the replace head light on my 8894xl shaver by do the following: Step 1 - Fully charge and clean shaver Step 2 - Turn on shaver holding down on button until shaver display recycles from 0 to xxx minutes. Step 3 - Turn shaver off Step 4 - Turn on shaver again and hold down button until shaver beeps ONCE. (Light will go off)
Posted on Aug 16, 2007
brector3
  • 1626 Answers
SOURCE: I dropped the razor and the removable head section
The head assembly (the part that flips up) for your model 7775X shaver si comprised of three components; the heads, the head holder and the retainer. These are always sold seperately and you can find them available at shaveroutlet.com. See links below.
http://shaveroutlet.com/norelco-philips-7700-series-cool-skin-head-holder-with-hinge.html
http://shaveroutlet.com/norelco-philips-7700-series-cool-skin-retainer-p-305.html
http://shaveroutlet.com/norelco-philips-hq177-cool-skin-replacement-heads-p-245.html
Posted on Mar 01, 2010
brector3
  • 1626 Answers
SOURCE: Arcitec razor 1050X will not cut whiskers
You are certainly not th first person who hasn't been happy with the Arcitec model. If it never worked well for you from the beginning, there is nothing that will make it work now. It's a shame that you've waited past the 45 day return period.
Your old shaver, 6885XL, was a "Quadra" model. These were a popular model type that is now discontinued. If you still have it, it may be able to be repaired. If you would like to replace it with another Quadr model, you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/norelco-7886xl-quadra-action-shaver-factory-refurbished-p-534.html
This model is virtually identical to your 6885XL except that it is a newer version
Posted on Oct 13, 2010
brector3
  • 1626 Answers
SOURCE: my batteries were holding a
It is advised that you change the batteries when you realize that they are no longer charging properly. Most likely, only the batteries need to be changed but it is possible that you have caused further damage due to leaving it plugged in continuously and the batteries may hae become corroded or leaked.
If you decide to attempt to change the batteries, you will fin the correct type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
You will find helpful videos on the item page to assist you in installation
Posted on Sep 24, 2011
Brand new mower smoking on first start
tie a rope on the handle and allow it to run for 5-min with no load on it if it doesn't clear up then return it to the store you bought it at
Aug 04, 2012 | Garden
I have two Mecablitz 60 CT batteries. They are about 10 years old and have not been charged since March, 2004. Should I dispose of them or can they be repaired for a reasonable cost?
The couple of dryfit batteries I've looked at have been shot. I don't know how old they were. Take a decent modern battery charger (the ones at WallMart are good enough) that will handle 6 volt and AGM batteries. Clean the contacts and jury rig a way to connect the charger to the battery terminals. If the charger doesn't register anything, it's likely the batteries have died. They will actually completely dry out inside, becoming inert. I've used $20 AGM batteries from Batteries Plus and they seem to work fine (though you either need to make a battery adaptor, or cut out the side of the battery pack to get them to fit.
Sep 11, 2011 | Metz Mecablitz 60CT4 TTL Flash
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Our bread maker doesn't heat at all, it will make the bread then just turns off. We've had it for about a year, we've made 10 loafs, maybe. Those were some expensive loafs of bread :( Any...
Contact customerservice@cuisinart.com for a service center near you.
Otherwise, try to reboot your breadmaker's computer by plugging it in then pressing and holding the Stop/Pause button down for at least 3 seconds.
Hope this helped. ;)
Jun 10, 2011 | Cuisinart CBK-200 Bread Maker
My B&D GrassHog CST2000 doesn't hold a charge very
Battery cases are usually welded closed and must be cut open to access the cells. The cells are also spot welded together to make up the battery voltage.
Jun 01, 2011 | Black & Decker Garden
My camera will not hold a battery chard, it last
How old is your camera already? Electronic gadgets powered by lithium ion batteries dies over time. if you had your camera and battery for over quite some time now say like a year or so, maybe the cells were drained dead and uncapable of holding electrical charge anymore. If that is the case you might consider replacing your camera battery with a fresh one.
Apr 28, 2010 | Nikon COOLPIX L100 Digital Camera
Keeps cutting off
if it wont hold a charge its most likely your alternator. and if there is no power CHECK THE OIL! and the transmission!
Apr 22, 2009 | 1995 Suzuki Sidekick
Norelco Advantage 5615 X Electric Shaver Logo
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
