Question about Hotpoint RLA80 Refrigerator
Door not closing properly.
The door seems to hang a little so that when it's closed it doesn't deactivate the switch for the light, nor does it seal completely. Is there some way to adjust the door so that it closes properly?
  • Kam Hussain Apr 01, 2007
    Thanks for the prompt reply. Could you please give me a little more detail on removing the door?
    Also I checked how the fridge is seated and it doesn't appear to be level, have tried to resolve this which helped a bit. Is this something that may be contributing to my door not shutting correctly?
    Thanks again.
    BL
  • Anonymous Mar 13, 2014
    lg lrfd25850st Our doors used to close and seal automatically, now we have be careful to force them closed. What's wrong?
    President:
  • 1,462 Answers
Take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
Posted on Mar 31, 2007
My garage door can be lifted up manually from the outside by inserting fingers under the seal and lifting it. This gives me no security. How can I fix this?
your door motor should switch off the door sensor once it is fully closed either to door has not been set up correctly so the sensor has not been deactivated when fully closed or the door sensor has been wired up to the open switch connector in the motor. so it thinks the open switch has been activated by key or keypad when the seal sensor is pressed.
disconnecting the seal sensor will mean if anything gets in the way of the door when it is closing it will not stop so there is a danger of injury or damage to the door. i would check that the seal sensor is wired up properly or get a door specialist to check your motor is not defective.
I hope this was useful.
May 21, 2015 | Building Materials
Garage door not closing on final closing position
Locate the limit switch on overhead rail.
This will be little piece of metal that hangs down and has 2 wires attached. No risk of shock.
Loosen the screw holding limit switch and slide bit more toward garage door opening to adjust final door position.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 20, 2013 | Electrical Supplies
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Drivers side door wont seal,
latch has probably broke internally if you can slam door and dosent close replace latch maybe 15 dollars from a scrap yard and takes about 25 min max tools needed star screw driver and flat blade to take door panel off
Feb 16, 2012 | 1994 Ford Taurus
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My Fridgidaire refrigerator door does not close tight every time without pushing on it.. There isn't any moisture around the door. The light switch button has put a dimple in the gasket. The button on the...
If it is placing a dimple in the gasket, this may be the culprit. Try taping the switch off with duct tape and closing the door to see if it seals properly.Also make sure you have all food items clear. this is another factor in doors not closing, especially freezers.
Jan 15, 2011 | Frigidaire Refrigerator Light Switch -...
Im having the same an issue with my Kia..the dorr light comes on and makes a beeping noise while driving.. i was wondering how i could fix it. Any suggestion would be helpful. Thanks
It appears that one of the door operated switches is making contact even though the door is closed. This is indicated by the interior light coming on and the beeping noise is alerting that the vehicle has a door not closed properly when the vehicle is in motion.
It could mean the door catch is slightly out of adjustment allowing door to sit slightly away from body. Try checking each door for a loose fit by pushing the closed door in, especially the driver's which gets the most use. There should be only a little movement as the sealing rubbers are squeezed a little more. If door catches are tight then it may be that the rubber pad attached to the door that pushes on the door switch button has compressed and is allowing switch to make contact.
Sep 16, 2010 | 2003 Kia Sorento
Door needs to be adjusted as it seem to be hanging lower on open
slightly loosen the bolts on the hinges enough to scoot the door into the correct position and it will stay until you tighten the bolts on the hinges. It may take a couple of tries but that is the way to do it until the door seals and closes properly =)
Jun 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
The door of the fridge does not close properly, You have to press hard on the door so that it closes airtight. Also, the freezer does not have a light.
The door closing can be a couple things. The door can be sagging. This can be fixed at the hinge pins. It can be overloaded with heavy things, causing the bottom to twist outward, this can be fixed by not storing as much weight in the door. And it could be the door seal. Replacement is required, if it doesn't have the elasticity that it should. I would try the first two things first, the door seals are not cheap. When it is fully aligned, close the door on a dollar bill. It should have a little resistance when pulling it out The more, the better.
The freezer light could just be a stuck switch in the door. Condensation can get in it and freeze when the door shuts, holding the switch in the off position.
Aug 28, 2009 | Kenmore Refrigerators
I have a 1.5 over the range fridgidaire microwave...it seems the door hangs a little low because in order for it to work you have to put your thumb on the bottom of the door to raise it up a little and...
Does it seem to hang low or does it actually hang low? Readjust it. There is a switch that may hang high when the door closes. You just have look at what does what and what ain' doing what it is supposed to. first.
May 04, 2009 | Frigidaire Over-the-Range Microwave
Hotpoint RLA80 Refrigerator Logo
1,312 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
