Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Replaced the defrost heater but does not seem to working correctl
Replaced the defrost heater and it does appear to work, however, the frost at the top of the evaporator does not clear similar to the bottom. Refriigerator is colder but shouldn't the evaporator fully clear when the defrost heater turns on?
Thank you
  • 71 Answers
Check the fan above the freezer coils (evaporator fan) and the defrost thermostat (located on the top of the coils), some fans won't run intill the defrost t'stat cools.
Posted on Dec 24, 2008
AFD2535DES refrig not cooling. Cleared out freezer. Behind the plate, frost is thick on evaporator coils. Used a blow dryer to melt ice. Replaced the defrost thermostat...not sure how to check it
Is the fan running in freezer .Frost can be cause by several things
Defrost thermostat not working ,evaporator motor not working, defrost heater not working and unit low on freon.
First check to see if fan is running then check heater and thermostat but the check these you will need a meter
Jun 30, 2017 | Frost Refrigerators
Samsung RS267LBSH/XAA evaporators (both the refrigerator and freezer sides) building up with frost. It works fine for about a week after defrosting with blow dryer, and then same problem happens.
Your defrost heaters are not working. The unit takes a week to freeze up and presto - poor cooling. Melt the ice and it works fine again till it freezes up again. Did you check out the defrost timer? Make sure that the defrost elements are not open.
Apr 30, 2017 | Samsung Refrigerators
Why does the freezer seem to be at a higher temperature than indicated?
Check the back inside wall of the freezer for s coating of ice/frost or snow like substance. If yes-- that is an indication that your auto defrost system is not working. As the frost builds up more, the temp inside will get warmer. Most common problem in the defrost system is a burned out heater behind that back wall, but could be several problems causing it.
Jul 12, 2015 | Refrigerators
Frost on coil in back of freezer it is a kenmore side by side
Hi and welcome to FixYa, I am Kelly.
Frost on the back of freezer is a sign of an automatic defrosting problem. On very very rare occasions the evaporator drain gets blocked with ice.
Should you discover a block of ice on the evaporator coils do a manual defrost by unplugging the unit, directing a fan into the freezer compartment for just over 2 hours with the freezer contents removed. (Makes a water mess so be ready) After the manual defrosting session... reload the freezer, plug the unit in ad return it to normal service. After 6 - 8 hours check for ice production. If you have ice production now... you most likely have and automatic defrosting problem where as the defrost cycle is not working correctl;y due to control problem, terminating early or the defrost heater and / or defrost thermostat is not working correctly.
If you want unit specif information.... I will need your COMPLETE model number.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Kenmore Refrigerators
Frig/Freezer not cooling properly
by the sound of it i would go for a new fan.
Dec 12, 2009 | Refrigerators
Hello, I have a problem with an LG fridge GRS392GCA. temperature inside the machine raises after a few hours. I discovered that the coil was totally surrounded by frost. I heated the frost. the fridge...
usually it is not the heater but the controller for the defrost.
Which is a plastic package on the side if the coil, plugged into the roof.
Replace it, they are not expensive and testing one is.
Sep 12, 2009 | Refrigerators
Frost free freezer icing up
It should still be covered under the warranty.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 02, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Freezer Defrosts on its own
Yes it is supposed to. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If it seems to defrost too long and start thawing the contents then the defrost thermsotat may be bad. It's purpose is to stop the defrost heater when the temp reaches around 32 degrees. If it doesn't work the heater will stay on for the entire defrost cycle and possible melt things.
Check here for how to check it and where it is. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Fridge not cooling well, frost in freezer,back wall and coils
Aug 17, 2009 | Refrigerators
Fridge problem
you have a defrostion issue reed to remove the back panel in the freezer behind this panel is the evaperator coil needs to be melted down because it is full of ice and frost, ahair drier will work well,put several towells down under the bottom of the evaperator to catch water runoff, after defrosting the coil inspect the defrost heater or heaters some of these can have one or two heaters the heaters are located behind metal gaurds in the evaperator if either of the heaters are bad (both)need to be replaced, if they show good then bad defrost timer or bad defrost termination thermastat wiring diagram behind frount bottom grill
Apr 12, 2008 | Refrigerators
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
113 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
