Question about Cameras
My Nikon D80 seems to not be letting in enough light, its struggling to do any exposures in a fairly well lit room, that are above 5th sec and regularly defaulting to 1600 ISO when in auto! I'm fairly well experienced and have checked all the obvious things like ISO etc. When you look through the viewfinder, it seems to be darker - any advice much appreciated.
  • neeshneesh Dec 19, 2008
    My Nikon D80 seems to not be letting in enough light, it has previously been fine. I have had it for 2 years and am an experienced user. In AUTO, it will not go above 5/10th sec with 3.5f, without pushing the ISO up to 1600, obviously not correct. The room is fairly well lit and does not require a flash. Through the viewfinder, it seems darker too. Is there an internal error, preventing the full amount of light to reach the sensor?
    Any further advice? All i can find is info on how to use the camera to adjust the exposure and i can guarantee, thats not the problem.
    Thanks
    Master:
  • 763 Answers
Try to adjust the settings from your camera like the mode of flash that could interfer the picture.
thank you for using fixya
CHARCOIS
Posted on Dec 19, 2008
  • 395 Answers
Found a message bord with a topic that might help you out
http://www.velocityreviews.com/forums/t565783-nikon-d80-dark-or-underexposed-photos.html
  • Cameras Master
  • 19,396 Answers
If you use built in flash this is normal, also this camera tends to underexpose pictures.
Adjust brightness and exposure time to fix the problem.
  • 2 more comments
  • Ginko
    Ginko Dec 19, 2008
    On internet discussion groups there are many pages on underexposed pictures on this and similar models.
    Apparently you should be able to fix this by adjusting the camera settings.
    I quote testimonials from Google discussion group Nikon D80 Dark or Underexposed Photos:
    If you are using the built in flash, it is very easy to get dark pictures.
    If you are using the SB600 with a dome diffuser, then all should be well
    even with a slow lens like the 18-70 zoom.
    I have found that my D70 does tend to under expose by about a stop. You
    should avoid judging exposure with the LCD. Instead look at the histogram.
    If the histogram shows underexposure, then you as the photographer have to
    do something. "
    "High end digital is a different animal than film.
    For best results you should be willing to learn to make tweaks to the image,
    preferably using raw.
    If you prefer P&S ("you press the shutter, we do the rest" paradigm) there
    is no reason to lug around a chunky dSLR and lens.
    In general, with digital, slight underexposure is preferable as digital
    capture has essentially zero overexposure latitude but can preserve detail
    with reasonable noise for about 1.5 stops underexposure.
    I assure you the D80 is a magnificent camera once you learn how to use it
    with basic image processing. "
    "Any expensive DSLR has a flash exposure correction menu item that can be set
    to make the camera call for more flash, and that may give you better results.
    But the underlying problem is that nowadays camera default settings seem to
    favor uising flash for fill-in only. There are several reasons why this is or
    isn't a good idea, but it seems to be the current fad. Gisle Hannemyr, a
    Norwegian writer/photographer, has written a fairly exhaustive treatise on
    Canon's implementation of this phenomenon and how to adjust your settings to
    make it work in your favor (or at least not get in your way)"
    "I set my D80 for plus one half-stop exposure compensation (read the manual)
    for daylight shots and one full stop for flash shots. It works great. Always
    check the exposure compensation icon on the screen before shooting, as it is
    easy to reset this accidentally."
    This is a professional camera, and you need to use customised settings if you want the best result.
    Follow the last user hint, and set the camera for exposure compensation on situations were you get dark pictures.
    That is the easiest way to proceed.
  • Ginko
    Ginko Dec 19, 2008
    Well in that case there is a fault, sorry but on this camera many users get mainly settings problems, I could not know from your first comment.
    Disregard the hints on settings.
    The camera has a fault, try first resetting to factory settings.
    Faults with underexposed pictures concern boards, lens and array sensor, let me see what I find on the specific model.
  • Ginko
    Ginko Dec 19, 2008
    If you have darker pictures on all circumstances and it is not a setting problem, then it is a defective defective CCD imager, that is the array sensor that captures the light, and convert it into a digital signal.and rarely a problem on one of the boards.
    Check also that the lens objective is clean.
  • Ginko
    Ginko Dec 19, 2008
    Do a factory reset in the following way:
    "Find the two buttons with green dots next to them on the top right of
    the D80. They are the +/- * and AF * buttons. Hold them both down for a
    few seconds. The top LCD blinks and everything is back to normal."
I need to find out how to use a 650 1300 telephoto lens on my Nikon D80. I can get the shutter to release but nothing is in the preview.
The 650-1300 lens does not have the electronics to communicate with the camera. You have to use it in the Manual exposure mode, without any help from the camera's light meter.
The D80 doesn't have the LiveView capability, which lets you use the LDC monitor instead of the viewfinder for framing your pictures. This has nothing to do with the lens. Nikon introduced this capability with the D3 and D300, which came out after the D80.
Feb 08, 2011 | Nikon D80 Digital Camera
I find that even in a reasonably well lit room my camera struggles to pick up a clear image and always appears to be a lot darker than in real life. I would assume that on automatic setting this shouldn't...
Try bigger ISO-setting (in a well lit room 400-600 and darker even 1600). Also try to fix the exposure according to the darker parts of the room.
Aug 05, 2010 | Cameras
Have Nikon D80 with 18-200VR lens. Am getting consistently overexposed pictures. Kindly advise. Thank you
Please check your exposure value (EV) settings. You may have raised this and forgot to move it back.
You should be able to play with exposure also via the Shutter, Aperture and ISO settings
Dec 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blue corners when shooting in BULB
With the same exposure settings, you should get the same result. When using Bulb in Manual mode, you also need to be sure you have set the lens aperture to the largest opening (lowest number). And don't forget to set ISO to 1600. Since the D80 has shutter speeds as long as 30" (minutes) I recommend you use them instead of Bulb, unless you need longer.
The blue areas are heat noise from long exposure -- other electronic components near the sensor are generating heat from the constant current flow. Be sure you check your Shooting Menu settings to set Long Exposure NR to ON and also High ISO NR to HIGH.
Apr 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
Bracketing won't work
Did you take the pictures in automatic mode or are you taking them in Program or Manual mode? Try switching modes. it sounds like you are looking to get different exposures for a given scene, so I'm guessing you are looking to take better photographs. Let me know about your other shooting variables that are set on the camera and I'll let you know.
Nov 27, 2008 | Nikon D80 Digital Camera with 18-135mm...
Problems taking pictures
How well lit is the space your in? Are you not using long enough of an exposure?
Sorry but I gotta ask, is the lens cap on?
May 02, 2008 | Nikon D80 Digital Camera with 18-135mm...
Exposure
Is your lens clean? was the subject extensively backlit, more than the rest? Half of photography is finding a location with even, pretty lighting. If lack of experience is your issue, check out this page: http://www.darjanpanic.com/photography/photography-lighting-knowledge-the-key-to-good-photos/
Otherwise... D80s are just... quirky. If it's a serious issue, send it into nikon - it costs all of 10 dollars to do so for a quote. Good luck. :)
Apr 05, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Jan 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Consistent under exposure
Under exposed should be minus not plus number.
Lucky you didn't buy Canon 5D or 1D- they have focus and exposure problems.
Hope you are not using the pop flash that is on the camera. If you are, then turn off the Red Eyes Modes.
Set camera to manual mode and lower the F number(open up to half or one stop).
What studio lights are you using? Increased the light output of studio by those number and shoot like you normally do.
atdlee@netzero.com
Dec 11, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Cameras Logo
18 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
