Question about Roper Washing Machines
The washer doesn't stop filling and the agitator isn't working. The drain and spin cycles still work.
    Scholar:
  • 111 Answers
One of four things is happening...
1. Your drain hose is too low or is too far down the stand pipe and is causing water to siphon out of the machine
2. Your water inlet valve is stuck open and will need to be replaced.
3. The pressure switch (water level switch) has failed and won't switch between fill and wash.
Does it flood the room? If not probably #1.
Does the water stop running when you unplug the washer? If so, #3
Can you only stop the water flow by turning off the house hot and cold valves? If so, #2
4. If none of the above, then you might have a clogged pressure switch hose. It is a hose that connects to the water level switch (pressure switch) on the top end and the outer tub on the bottom end. It may have gunk plugging it up on the tub side preventing air pressure build up to trigger the water level switch. If so, remove the hose from the tub and clean out the end of the hose and the air dome that is attached to the tub. What brand is your machine?
Posted on Dec 19, 2008
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
    My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
    Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
    Will not go in to spin cycle
    Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
    May 09, 2009 | GE WBSR3140DW Top Load Washer
    98702 Washer Drain/Spin Dead.
    My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
    Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Washer clothes
    Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue. 1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working. 2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line. Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
    Aug 09, 2007 | Whirlpool LSR5132J Top Load Washer
    Washing Machines Logo
    115 people viewed this question
    Top Roper Washing Machines Experts
    Marvin
    Marvin
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
