Question about Sony J3 902 VCR
Sony j-3 check the hours
I need to check the hours on drum and head. how do i do that.
thanks---Manju
Head
hello,
showing error c:31 mean your camera have defective mechanic, which one contain error? well, to make sure your problem try to inserting cassette and see the mechanical work:
1. when tape is insert it, before reel try to raising the tape, head will spin first.
2. after head is spinning then the tape will load
if your problem is in no 1 the head drum doesnt spinning, try to check the flex cable the top section of the head.
if head drum is spinning its mean your capstan is broken, try to change with a new one
thanks
otto
Jul 17, 2013 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony PD 170 error code c3211
hello,
well it seem your mechanic problem. i have similar problem and i solved it.
first see the mechanical work, when the tape is insert it, see the drum head, is the drum is spinning? if not mean your flex cable in the top of your head drum may damage. or try to reconnect it.
if the drum head is spinning its mean capstan doesn't work, your problem is in here. try to change your capstan part.
if there still problem, i can help you freely just email me at otto.engineering@hotmail.com
or you need manual service i can share with you
thanks
otto
Jan 24, 2013 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Very slow at start up and shuts down at will.
hi, ( O.S - win XP / windows 7)
u need check the system virus/spy virus/Had disk bad sector. 1. After system ON press F8 key 3. Select the safe mode with command prompt 3. Type : chkdsk and enter it will check the bad sector,lost clusters,cross -linked files and lost clusters, directory errors. 4.If u found any Bad sector - u need format with Low level format Hard Disk / if not any bad sector (a) Run with Anti Virus with latest updates.
Rgd, Manju
Feb 10, 2010 | E-Machines eMachines Desktop PC
PD 150 will record but,during the play back you see several horizontal lines covering the image. What causes it? & How can we repair it? Please help. I used a brand new tape & I have used this...
The problem is of drum assembly which normally called Head of the camera, it needs replacement. When horizontal or vertical lines appears it means the drum start malfunctioning and it needs replacement. For this please see the link click here.
Thanks.
Nov 25, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Looking for Vga and sound drivers
Hi.. This is Manju here.. click on start and select Run.. then type dxdiag this command then give ok.. there you can the system manufacture and model no
Thanks & Regards
--Manju
manjunath_pg@yahoo.com
Apr 25, 2009 | Computers & Internet
I need a VCR-Head Drum (New) for my Sony VCR which has got SP/LP
Check the Video Output Flex .... Sumtimes if its broken it creates that problem
Dec 07, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
No picture
I assume this symptom appears when attempting to play a tape? If the picture is mostly snow, VCR may need video head cleaning. To do this, take the top cover off- You will note a cylindrical shiny aluminum drum- the actual heads are at the lower edge of this rotating drum.
Anyway, use a lint free cloth or special wipe moistened with rubbing alcohol, or product specifically made for such, carefully cleaning those heads as well as the drum itself. Occasionally, it may take 2 or 3 cleanings.
If the VCR has lots of hours, or abrasive head cleaners have been used, the head could be worn out. If so, toss the rig and purchase a new one. Head replacement is non-economical unless you have a high end machine.
Jun 12, 2008 | Sony SLV-R1000 S-VHS VCR
Head Hours
Nope it's in the user menu and you have to have video going into the deck to read it on the monitor video out put. Head hours are the time the tape actually is in contact with the drum and the most accutate easy indication of drum ware. 3/4 Umatics don't eat heads as a rule. I think I only replaced 1 out of hundred for thousands and thousands decks. Brokers love head or durm hours tipically it's T2 on the menu.
Jan 21, 2008 | Sony VO-9800 VCR
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
Not able to write to CD-R directly
Problem: with Sony Handycam.......... DCR-HC26
After installing the disc that came with the camera and the wizard, and some other programs, Picas, my computer does not find the camera . Says I need a CDR driver also. Can I find one to download free someplace?
Thanks.
Jack
Sep 03, 2006 | Sony Handycam DCR-TRV265E Digital...
Sony J3 902 VCR Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
