Question about Rinnai Webstone The isolator EXP tankless water heater Service Valves WRIK
Vinegar flush I have a Rinnai tankless water heater. (runs great) I need to do some PM on it. How do I proform pm on this unit such as vinegar flush?!
  • stmada Jan 30, 2009
    In the manual it describes using a circulating pump to pump the vinegar through the unit. Is that a separate pump or is that built in to the unit. The manual says to turn power on to the pump, but I don't know how to do that.
  • mudcitynomad Apr 10, 2009
    Is the only solution to the Rinnai tankless cleaning the $100 flush kit?
    Problem Solver:
  • 6 Answers
You should not have to flush unless the code LC comes up. but here is the flushing diagram.
Posted on Aug 01, 2009
  • 1,420 Answers
First you will need to isolate the domestic water supply and hot water going to your faucets. Then just pumping thru the boiler a 50/50 mixture of white vinegar and water. The longer you do this, the better. Then rinse wit fresh water. When you connect back the supply and hot water, don't be surprised to smell vinegar for an hour or so.
Posted on Dec 19, 2008
  • 3 Answers
The pump in the $100 flush kit I've seen is just an Attwood WaterBuster cordless utility pump that Wal-Mart sells online for around $35. A $20 bilge pump for a boat might also work if you have a 12V battery around to run it. A/C Utility pumps seem to start around $70 but I'd rather not mix 110V with water if I don't have to.
Posted on Dec 09, 2009
  • Busta Rhymes
    Busta Rhymes Nov 26, 2013
    What do you think regular tank water heaters run on? Magic?
  • hubschrauber Nov 26, 2013
    Water pressure and natural gas... and if there is electricity for a spark starter, it is typically a well protected, professionally installed fixture. Considering the type of people who read and comment on posts like this, I didn't think it would be very wise to encourage dangling a 110v sump pump by the cord over a tub full vinegar.
Our rinnai tankless hot water heater keeps shutting off
It only runs when there is a demand for hot
water.
Mar 25, 2017 | Rinnai Water Heaters
I have a wall mounted tankless water heater for
It's scaled
Do you have a softener? Water must be 15 GRS/PPM or less in iron and calcium. Hot spots in unit are boiling water and are causing the noises.
Descale and flush unit following Rinnai Specs and check water hardness for compliance with Rinnai standards because too hard an inlet water will VOID the Heat Exchanger Warranty (10 year).
Oct 19, 2014 | Water Heaters
How do I flush this unit
1) Copy following link for steps showing how to run white vinegar through Rheem tanklessx heat exchanger to partially remove scale that coats heat exchanger and reduces unit efficiency and causes error code IL:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
2) Tankless are prone to scale inside heat exchanger and require yearly deliming to mitigate effects. Do the required yearly maintenance to avoid common error codes.
3) Expected cost of maintenance and repair is more expensive than estimated $1-8 monthly energy-bill savings from owning tankless.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 31, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
I have a Rinnai R75LS and have it hooked up to clean with vinegar. However the R75LS will not allow the vinegar to flow through. I have watched videos etc. and seem to be unable to get the vinegar to...
I'm assuming you heater will let water flow through and it's not completely blocked with scale. There is a motorised valve that needs to be open. Start with the heater connected normally and run a hot tap. While it is firing turn off the power, this will leave the valve in it's open state.Now connect up your heater to the vinegar supply; do not turn the power back on.
Sep 16, 2010 | Rinnai Webstone The isolator EXP tankless...
The flow is more than it used to be when the Rinnai was working fine with two faucets flowing probably triple the advertised flow rate now. It still cycles hot and cold every few minutes. Is build-up a...
when your tankless starts cycling hot and cold water, then there is probably scale buildup inside the unit.
flushing the unit will remove the scale and any other debris inside the unit.
you can do this yourself, do you have the instruction book that came with the tankless heater?
it is recommended to flush the unit once a year especially if you have hard water.
it takes an hour or maybe a little longer to flush the unit completely.
Aug 29, 2010 | Bosch & Tankless LP Hot Water Heater
Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Nov 28, 2009 | Rinnai Water Heaters
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Sep 21, 2009 | Rinnai Webstone The isolator EXP tankless...
I have a Rinnai system. Good cold water pressure, little hot.
What type of pipes are install on this heater?
Mar 13, 2009 | Water Heaters
My rinnai has build up in the heat exchanger
  • you have a lime controll issue , you need to flush the unit using food grade vinegar. go to the rinnai web site for instructions. it is a pretty simple solution they make a kit to flush your unit if it was installed with an isolation kit.
Nov 15, 2008 | Rinnai Water Heaters
Rinnai Webstone The isolator EXP  tankless water heater Service Valves WRIK Logo
3,168 people viewed this question
Top Rinnai Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Paul Nielson
Paul Nielson
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
