Question about Acer 17" AL1706B LCD Monitor
Acer P193W Monitor Problems
I have a P193W Acer 19" Widescreen Flat Monitor. It was fine for the 1st 2 weeks i had it then when i switched my pc back on 1 day a grey screen with random blocks appeared for a few seconds then the monitor went off again then a complete grey screen stayed on.
The monitor went back to the shop i bought it from (Brighthouse on Hire Purchase) and they took it away for repair. It came back 1 week ago working fine until this afternoon. I switched the monitor off while i went out for no more than 30 minutes and when i came back i switched the monitor back on and the grey screen with random blocks appeared, went off again then a grey screen on the display. I've just phoned the shop and they are going to take it away again. I want them to come and have a look at it in my home so i can show them the problem.
I used my camera phone to film what it was doing and i also filmed my old CRT monitor (which i am using now) to prove that it is not a fault with my pc.
The Engineers report says : The unit has been tested and no fault has been found.
Has anyone else had this problem? Does anyone know what the fault is? How do i prove that there is a fault on the unit?
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
  • 4 Answers
SOURCE: monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
Posted on Dec 11, 2007
SOURCE: menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Posted on Feb 28, 2008
  • 121 Answers
SOURCE: display does not fill screen completely
ok right click anywhere on the screen go to the bottom and click properties now there will be a couple of tabs at the tom desktop screen saver you want settings raise your resolution to about 1200 x800 or higher i think native for that is the 1680x1240 this should fix your problem
Posted on Nov 25, 2009
paulbtorrent
  • 34 Answers
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
Screen blank
mcdevito75 here, Check all connections at monitor and at computer, check all controls on the monitor itself also, check the on/off switch on the monitor. Monitor could be burned out. Make sure computer is on also.
Jun 26, 2010 | Acer 19" Widescreen Flat-Panel LCD HD...
Acer monitor al1917w-a problems
I assume that you already try this monior with other PC and still get the same problem. You may have to open it up and inspect the inside, look for bad components such as capacitors in the power supply, the problem can also be inthe backlight inverter circuits also. See example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 26, 2010 | Acer AL1917W LCD Monitor
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops. http://en.wikipedia.org/wiki/Capacitor_plague
Common problems fro 2~3 years old monitors/ TV.
Jan 03, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
I have an Acer AL1916W the power switch lights up brightly but when computer is switched on switch goes dull and and screen stays blank...Found two Capacitors that were bulging they were 220mf 25volt....I...
Can you send me a picture of the boards in your monitor? We work on Acer units all the time.
Buddy
Corporate Computer
www.ccl-la.com
buddy@ccl-la.com
Over 21 years of PC and printer support/repair
Jun 28, 2009 | Acer AL1916W 19" WideScreen LCD Monitor
Acer monitor
What do you mean by it takes awhile to come on? Sometimes with these monitors depending on the type you have it takes time for the PC to pick up the signal. I have my PC hooked up to a KVM switch and it takes about 10 to 20 seconds for my monitors signal to be recognized.
Nov 15, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
320 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
