Wahser fills with water, but will not agitate. It drains and spins. washer is about 7 years old from sears. I don't have the manual. please help.
You need to check the lid switch, does it click. you can unplug and then remove the 2 screws to see it, if it looks like it is coming apart then the lid switch is bad. you can buy one for about $40 or so dollars. i am assuming it doesn't spin either.
ok i want you to open the lid and twist the agitator, the agitator sits on top of the shaft in side the drum. if you can twist it back and forth with out it grabbing anything, then your agitator dogs are bad. they cost like 5 bucks. pop of the little lid on the agitator and then remove the nut at the bottom of the agitator. replace the 4 little dog ears, they look like tear drops or commas with teeth. just pay attention on how the come out so you can put them back in. kelly
YES THE WASHER SPINS. IT WILL NOT AGITATE.
