Question about Acer 17" AL1706B LCD Monitor
Acer P193W Monitor Only Has A Grey Display
I had the monitor for 2 weeks when the problem 1st appeared. I switched my computer on and the monitor flashed up a grey screen with random grey blocks then went off, back on again with a complete grey screen. Brighthouse (where i bought it) took it away for repair (it was gone 4 weeks) and i got it back on Friday 12th Dec 2008. It was working fine until today when i switched it off for 30 minutes as i went out and when i came back it was doing the grey screen again.
My old CRT monitor works fine plugged into the same slot.
Can anyone help?
    Master:
  • 604 Answers
Bring it back for repair
Posted on Apr 25, 2017
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
SOURCE: Monitor Flashes Gray, Then nothing
It is an LCD i forgot to mention that
Posted on Feb 17, 2008
gtjr
  • 31 Answers
SOURCE: poor screen quality
re install your dell video card driver
Posted on Oct 19, 2008
leroyal
  • 2120 Answers
SOURCE: Monitor Problems
It has a 3 year warranty.
Posted on Mar 16, 2009
rajeish
  • 52 Answers
SOURCE: Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Posted on Aug 04, 2009
    Mijn beeldscherm blijft steeds auto config
    Elke monitor heeft een menu-optie. Zoek met uw handleiding hoe u uw menu-opties voor uw specifieke model en daar toegang te krijgen is een optie om berichten of waarschuwingen weer te geven. U **** het uit daar.
    Jun 20, 2012 | Acer LCD Monitor P193W
    My acer AL2416w monitor turns on to a black screen
    I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
    Sep 06, 2009 | AcerView 77E 17" CRT Monitor
    Monitor comes up shows "acer" then says no signal and goes black
    This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
    I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
    Apr 24, 2009 | Acer X241Wsd Monitor
    Acer monitor cable/ accessory
    the best way to do what you are describing it to have 2 display adapters installed...and use your 1st display for your monitor and the second for the digital receiver..... then you would optimal performance and have more video memory for each display allowing faster productivity
    Jan 07, 2009 | Acer AL1916W 19" LCD Monitor
    Acer P193W monitor stretched image
    What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
    tallcoolone@yahoo.com .
    Jan 04, 2009 | Acer X193W LCD Monitor
    Acer AL1716 Power problem?
    i have experienced the same problem (power cycles on and off and on and off... nothing but Acer logo and black screen) on 2 Acer model 1706 A version 1706 Ab monitors both built in July 2006. Before the customer reported the 2nd monitor with the same problem, i sent the 1st one into Acer for warranty service (after testing in on 4 machines w/4 different video cards). They shipped it back with a paper saying the monitor was repaired. I returned the monitor to the customer and it exhibited the same symptoms (aka, not repaired). Could there have been a bad batch in July 2006? When I plug a new Acer AL1716 monitor into the same computers, I have no problems at all.
    Jan 18, 2008 | Acer AL1716 17" LCD Monitor
    Computers & Internet Logo
    121 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
