Question about Intel Motherboard
I have msi945 board
My front audio pannel is connected in the motherboard but when i connect a audio device in front audio panel then sound doesnt come in the my device i.e headphone.
it would be coool if dont have to plug my device in the rear pannel m sick of sliding my cpu
my system requirements are;
intel 3 ghz processors
2gb ram
400gb hard disk
and the next problem is
i cannot go to bios setting
when i press del button after restart then cmos setting opens but i need a bios setting
    President:
  • 1,179 Answers
Try checking the front panel in bios. It may be disabled there which would mean the front panel jacks would not work. Hope this helps.
Posted on Dec 21, 2008
Dear i have problem in my frent panel cuble... can you tell me where i put these cuble
On the mother board 3 plug in connecters are there
USB 1
USB 2
Front Audio
You can connect the front pannel cable accordingly.
Apr 28, 2011 | Intel Motherboard
My front panel audio and microphone doesn't work
try to check the connection on the board wether its proper if no then check the manual of the board it will help u also check the setup in the bios also there r setting in some program of the sound software check this should solve the problem thankyou
Nov 16, 2010 | ASUS P5KPL-AM SE Motherboard
I have pront panel audio and usb port but am not able to connect the pin can you please explain me the pin diagram to connect my front pannel usb and audio
depends on what board you have?
majority have the same pin outs tho,
http://www.vistax64.com/attachments/sound-audio/8065d1227471405-realtek-audio-jack-mixup-capture.jpg
there is link to a page that explains both F_USB (Front usb ports) and F_AUDIO (front audio connections)
Aug 31, 2009 | Computers & Internet
Front panel audio failure-DG33FB Intel mainboard
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Jun 03, 2009 | Intel D865GBF Motherboard
Analog front panel conections need map to board connections
Here your connection...
Front pannel
http://www.geocities.com/jisfy/Front-P.JPG
Front Pannel Usb Connection
http://www.geocities.com/jisfy/USB.JPG
Thanks if it helpfull please rate me.
Mar 26, 2009 | Biostar M7VKQ-PRO Motherboard
Plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
goodluck...
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
USB
The USB ports on the front panel allow convenience for devices which you might connect and disconnect from time to time (like portable media card readers for example, or USB-camera cables) so you don't have to reach to the back of your case. If you are going to use the front panel USB ports, make sure they are connected to the motherboard inside if you are not using a store-bought computer.
Let me know if that answers your question.
Jan 11, 2008 | Zerus Intel Desktop Board D815EEA...
Help pls....
http://www.intel.com/products/i/motherbd/D946GZIS/D946GZIS_lg.jpg
connect the front panel audio to the yellow coloured header you can see near the white coloured PCI Slot. in the above picture it is shown in the top right hand corner.
Dec 24, 2007 | Intel D946GZIS Motherboard
Flash Disk goes bad
Did you assemble the board yourself into the case? check to make sure your front panel USB connections are installed onto your motherboard in the correct order. Refer to your Motherboard Manual.If they are not, they can fry your usb devices rendering them inoperable on your pc or others. I have seen this before because of improper installation of front pannel USB connections. Good Luck
Apr 09, 2007 | Intel D915GUX Motherboard
Intel Motherboard Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
