Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Pump is not starting to pump water out of whirlpool ultimate 2
Washer not draining water. Will wash, but pump will not empty water. The washer has set for 8 months without being used, as it is in a winter home. The first load I washed, it just stopped after the wash cycle. Also the lid switch is bad, and needs to be replace. Please advise
  • 61 Answers
I suggest you purchase a lid switch from a local supplier of parts or call a local servie tech if it's just the lid switch it should not take a tech long to change it.
Posted on Dec 19, 2008
Washer will not drain
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitates fine but water will not empty out??
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced in this case.
Oct 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Leaking washer drain pump
Yes, the drain pump is a common leak area.
2 clips, 2 hoses and it pulls off.
If it has leaked for a long time you will have to get aggressive to get it off.
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Laundry comes out very wet
Hello tcburns07,
If possible, can you cycle a very small load of wash ( perhaps a towel or two) on the lowest setting to validate that : the washer is spiining up to normal speeds while draining water and that the water being drained is complete? Chancves are you have a either a blocked filter that limits water from completely draining, something in the drain pump or a restriction in your drain system. You could also have a worn belt that drives the pump. The test I suggested will at least determine if your washer is capable of draining all of the water from even a small wash load. Try that and let me know the results.
Regards,
Rick
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water Coming out the bottom of the washer
lean washer back and ck pump for gray area on white pump back probably hole in pump
Jul 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
http://www.fixya.com/support/r397092-replacing_water_pump
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Jun 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Zanussi washing machine
Check your filters first, then the pump. Refer to your manual; or click troubleshooting above.............sure would get some tips.
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
69 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
