Copier is not copying
I'm printing, and copying and my pages are coming out blank. I've tried a new cartiridge and still have blank pages.
  • barrylee66 May 11, 2010
    you must be more specific and give a model number
    Problem Solver:
  • 7 Answers
Possible broken charging wires (corona wires) (chargeing wire) no charge on the drum will not pull developer or broken (transfer wire) will not pull image off drum resulting in blank copy
Posted on Dec 22, 2008
I haven't used my printer in a while so when I try to print something the pages come out blank, but my ink cartridges are full. What could the problem be?
Have you tried putting it through the cleaning cycle found in the list of options on the screen? Also, does the page come out blank for copies as well as printing?
Jul 06, 2015 | Brother MFC - 255CW Fax / Copier / Printer...
I send a print but pages aqre blank
Does this happen when copying? Can you print internal copier form meter count etc.?
Mar 14, 2014 | Konica Minolta bizhub C250 All-In-One...
Replace toner and drum and when i make copies they come out blank
This comes from the manual for your device:
A blank sheet is ejected.
You placed the document facing the wrong way when using the copier.
The other party placed the document in their fax machine the wrong way. Check with the other party (KX-MB781 only).
Try putting a page in and seeing if it copies blank and then putting it in the other direction. Have you had the same issue with printing?
If everything comes out blank it is the fuser or heating element.
Oct 25, 2012 | Panasonic KX-MB781 Laser Fax, Copier,...
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
All new ink cartiridges and pages come out blank now
please follow these steps:
1. reseat all of the ink cartridges
2. perform a cleaning cycle using your computers maintenance options
if you are using windows go to the control panel then look for the printers and faxes folder, right click on the icon of your specified printer then left click go to printing preferences.
on printing preferences click on the tab for maintenance then look for head cleaning. do it for 3 to 5 times then test by printing nozzle check
if it does not work the possiblity is that the nozzles might have been clogged with dried inks. try spraying it with wd40 then let it dry for 3 to 4 hrs then print.
take note that doing the head cleaning you can take a considerable amount of your inks
Sep 23, 2009 | Epson Stylus C86 InkJet Printer
NO PRINTING
your laser shutter is not opening properly you will need to have serviced by service tech
Mar 04, 2009 | Canon Office Equipment & Supplies
Printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
ImageRunner 400S works, but prints a blank page
check the drum is seated well or not,check the drum drive lock, check the drum is rotating freely or not.check the chargin g rollor are seated well or not
finally replace the drum and see the result.
best of luck.
Aug 13, 2008 | Canon imageRUNNER 400S Copier
AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Nov 05, 2007 | Sharp AR-M455N Copier
212 people viewed this question
jasbo
jasbo
