Question about Fellowes P70CM Shredder
The gear opposit the drive motor broke (driven worm gear)
Need a driven worm gear for my Powershred PS80.
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
The motor is turning but the wheels arent moving could it be the gears are disengaged or a problem with the transaxel??
hi Delores , you need to make sure the coupler that interfaces the gearbox to the motor is not broken, if that's okay then must likely the motor worm interface gear is spinning across the main Drive worm gear, I can engineer new worm gears but they can be costly, cheaper than a new transaxle in most cases ...
Regards
Rob
Dec 19, 2015 | Afikim Sportster SE
Motor is turning but wheels arent moving could it be the gears or transaxel
Hi Delores , you need to make sure the coupler that interfaces the gearbox to the motor is not broken, if that's okay then must likely the motor worm interface gear is spinning across the main Drive worm gear, I can engineer new worm gears but they can be costly,cheaper than a new transaxle in most cases ...
Regards
Rob
Fellowes Powershred PS80. Took bin out to empty, now wont run.
Had similar problem. Make sure there is absolutely nothing stuck in there. Get the vacuum on it if you have to. It is simply not making proper contact.
Jan 25, 2014 | Fellowes Office Equipment & Supplies
Repair
There are no adjustments for this machine. Chances are that the plastic gear that is driven by the worm gear has a spot that is worn down and when worm gear hits this spot, it does not drive . Replacing gear is the only remedy. Good luck.
Jul 13, 2013 | Fellowes MS-460Ci Shredder
Error on elsafe screen ''ser''
will need the make and model from your vacuum to answer this question.
Mar 06, 2011 | Vacuums
I changed the gears in my craftsman 1/2 hp , chain-driven garage door opener and now the door only goes up a few inches before it goes back down. Any ideas what to do next?
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Gear is broken. Where can I find a replacement part?
Good luck, Tom
Mar 14, 2009 | Fellowes Powershred SB-80 Shredder
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
95 Ford Explorer Odometer
Check the speed sensor in the transmission.
Being a 95 it might still be cable driven. Disconnect the cable from the transmission and hook a drill to it. Spin it and see if it registers. If it does, the gear going into the tranny is broken, if it doesn't the cable is probably broken.
Jul 23, 2008 | 1995 Ford Explorer
Fellowes P70CM Shredder Logo
388 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
