Question about LG Vu CU920 Cellular Phone
LG VU SCREEN PROBLEMS
My screen on the LG VU has a swirl in the shape of a box down the middle of it. You know how you touch a lcd screen and it gives you that swirl from the touch. Well, thats what is permanently in my phone. Its never been dropped or anything. How do I get this off.
  • 1 more comment
  • laprincesa20 Jan 23, 2009
    I have the same problem. Actually I got my phone in August and by October it had gotten that rainbow thing. I didn't wet it so I had no clue what it was. I started to have some small issues with the touch response while typing text messages. I would go to type one letter and something totally different would come up. I have insurance so I got a new phone sent. Now again 3 months later I have the same issue with this phone - completely out of the blue.
    I dont want to get another replacement only to have this happen again.
  • Anonymous Apr 01, 2009
    I have the same issue. I've only had the phone a couple of months. Does anyone know if it is covered under warranty?
  • Anonymous May 22, 2009
    I have that exact same thing on mine, no drops no nothinnnnn
  • 26 Answers
You might have pushed down 2 hard on the screen if it is purple then thats the case
Posted on Aug 07, 2009
How do you get a touch screen to work the phone is working but the touch screen isnt
LG has released a line of cellular phones that come equipped with a sleek touch-screen LCD display. Since these screens are high-tech and sensitive, they can be prone to damage or scratches. If the touch screen on your LG is damaged, and you don't have the money to take the device to a service technician, you can open up the phone and replace the touch screen yourself.
1. Turn off your LG and slide the back battery door down and off of the device. Lift the battery out of its compartment and use your Phillips screwdriver to remove the four screws located on each corner of the compartment.
2. Use your fingers to remove the back panel from the phone. The green motherboard will be revealed underneath.
3. Unplug the four ribbon cables that connect at the middle of the motherboard. Unplug the antenna cable in the top-right corner of the board. Lift the motherboard out of the phone housing and set it aside.
4. Use your Phillips screwdriver to remove the two screws located at the top of the phone housing, then separate the back frame from the front housing of the phone.
5. Lift the damaged LCD screen out of the phone housing. Replace it with a brand-new LCD screen (available from your LG retailer or online) and reassemble your phone in the reverse order you took it apart.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | LG Vu CU920 Cellular Phone
My touch screen is not responding and acting sporadically
This is a common problem with the LG VU
Take a look at the following link for videos about taking out the touch screen and how to put the touch screen digitizer back in the LG CU920.
Remove and Replace Touch Screen on LG VU Cu920
Jun 14, 2010 | LG Vu CU920 Cellular Phone
Touch screen on lg view does not work
This is a common problem with the LG2_bing.gif VU
Take a look at the following link for videos about taking out the touch screen and how to put the touch screen digitizer back in the LG2_bing.gif CU920.
Jun 05, 2010 | LG Vu CU920 Cellular Phone
Touch screen isn't working
this also happened to me, the screen from the inside is either cracked or had blown out (stopped woking because of maybe over heat or some other bizzare reason, the only way to know for sure what happened is to obviously open the phone) you have to buy a 60 to 70 dollar (US dollar) lg LCD screen, and tool kit to open the phone, take out the lcd, and put the new one it if the old lcd is fine, then return the lcd that u bought and call warranty. a new lg vu cost around 100 to 120
Apr 08, 2010 | LG Vu CU920 Cellular Phone
I can't press buttons using my screen and when i press the screen i a swirl like shape
your screen need calibaration.calibrate your touch screen time to time regularly for better acessing
Feb 26, 2010 | LG Dare VX9700 Cell Phone
My touch screen has a oil looking spot in the middle of it and causes my scrren to mess up
The same exact thing happened in the middle of my phone, and shortly after to my aunt's LG VU as well.... it might e a common problem. I just bought a mirror screen protector off of Amazon and it covers it and makes the phone look better....I don't know how to fix it though. May have to get it replaced =/
Jan 25, 2010 | LG Vu CU920 Cellular Phone
My lg vue phone screen is frozen and i cannot get into the phone
You need to replace touch pad. Parts cost around $25. Fairly easy to replace. Once you see it you will know how to replace, Go on ebay and put in lg vu touch screen and you should pull up parts for your phone. Or just google lg vu replacement touch.
Oct 26, 2009 | LG Vu CU920 Cellular Phone
My new, barely a month old LG VU cell phone got cracked.
Try checking LG-Vu.com, great site and they have an LCD Replacement Guide, which could prove helpful in this situation, ;). Become a member there as well, very fun :).
Aug 25, 2009 | LG Vu CU920 Cellular Phone
Some how my lg vu screen is cracked on the inside. not the outside screen but the internal screen. i bought a new lcd screen. i need directions on how to take it apart and install the new one
ebay sells the lcd. the part is about $50. I have an lg vu and i just took it apart and put it back together in about 10 minutes. As long as you are a patient person with a set of mini screwdrivers, I think its pretty doable. I just replaced the lcd for a 2g iphone, and it was pretty hard, but mainly because the case is extremely hard to open.
good luck!
Mar 27, 2009 | LG Vu CU920 Cellular Phone
Lg vu screen responsiveness
You may try touch calibration.
To do this, first go to the main menu.
Choose the last tab on the right-hand side of the screen and choose 'More'.
Scroll down to 'Touch Calibration', selct, and then follow the instructions that appear on the screen.
Aug 23, 2008 | LG Vu Cellular Phone
LG Vu CU920 Cellular Phone Logo
684 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
