Kenmore Elite H4 Model #11045992400
Where can one purchase the Central Control Unit?
  • 5,911 Answers
Any one of these websites should suffice:
searspartsdirect.com
repairclinic.com
pcappliancerepair.com
appliancepartspros.com
All offer great service with competitive pricing. I would recommend checking out each one for the best price. I hope this helps you.
Posted on Dec 20, 2008
Kenmore Elite Oasis top load has a code of F 71?
F71 is no communication detected from the User Interface to the Central Control Unit (CCU). This could simply mean a loose or poor connection between the two communicating boards.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the three screws attaching the top panel to the rear of the washer then slide the panel rearward and lift it off the washer.
Disconnect the User Interface ribbon connector from the left side of the Central Control Unit (CCU) and clean the connector and terminals thoroughly. Reseat the connector several times to ensure a good connection between the Central Control Unit (CCU) and the User Interface.
It is highly recommended to clean and reseat every wiring harness connector from the Central Control Unit (CCU) to prevent the same problem in the near future.
Reconnect every wiring harness to the CCU and make sure all connectors are firmly seated. Slide the top panel back into position and secure it to the rear of the washer with the screws previously removed.
Apr 25, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer HE3T mod # 110.49972602. Unit had F70 error code. Unplugged and replugged. Now, no display on panels, power button beeps 3 times but nothing else.
Hi
F70 is a communication error between the central control unit and the user interface. First check the continuity of the user interface harness and then check the wire harness connections to the user interface and the central control unit. If the drum rotates then replace the user interface, if the drum is not moving then replace the central control unit (CCU). Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Kenmore Elite 45986 Front Load Washer
What is the f11 code?
the code is for Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
repair:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • MCU (motor control unit ) found next motor CCU found on top of unit under maun cover.
  • Mar 10, 2011 | Kenmore Elite 45986 Front Load Washer
    My Kenmore Elite HE 4T has just started to stop with a code F11 , can you please explain. I have tried to switch cycles but that does not help
    Thought this info might help.
    F/11 Serial Communication Error
    • Check MCU
    • Check CCU
    • Check Motor
    Feel free to ask anything else.
    Jan 19, 2011 | Kenmore Washing Machines
    Washer will not turn on flasheing F71
    F71 error code USER INTERFACE HEARTBEAT FAILURE
    If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit. Possible Causes/Procedure 1. Check for continuity of the User Interface harness. 2. Check wire harness connections to the User Interface and the Central Control Unit. 3. Replace User Interface if drum is rotating. 4. Replace Central Control Unit if drum is not moving.
    Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
    I have a kemore Elite HE3 with a F11 code. It will restart and run for another min or so. I have checked the wires and connections
    • Check MCU
    • Check CCU
    • Check Motor
    Jan 09, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite he3t
    maybe a false code if so may mean new control bd ..tech sheet is behind bottom panel with all fault codes if not on there code is a glitch in control
    Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE5 Electric Dryer
    I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
    May 07, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite HE 5t
    Hello
    Please see this weblink here for a ton of info on your problem.
    F11 = Serial Communication Error. Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Do this = Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    Check the Drive system for any worn or failed components.
    Please rate this post, if you are happy with my response. Respond back to this post if you need more help!
    Jan 09, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    147 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
