Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I'm getting an electric shock when i touch the door
If i don't have on shoes i get a shock from touching the door of the freezer side of my Kitchenaid refrigerator. The wall receptacle is working fine. There is no water in the condensation reservoir underneath.
What would be the likely case and how do i search for the problem and fix it?
Thanks,
Andre Simons
  • Anonymous Apr 24, 2009
    I have a similar problem. I haven't fixed it. My hunch is that there is a short in a motor, since the ice dispensor is broken too.
  • AHinCA Apr 24, 2009
    I similarly have gotten a shock from the freezer door of my side by side KitchenAid. Additionally, the ice dispenser is not working. I suspect (with no proof) a motor with a short.
    Problem Solver:
  • 12 Answers
Somehow the door is charged with electrity and when you have shoes on your insulated, meaning that your not a place for the electricity to travel thru, but when you take away the shoes the electricity can go thru you to the floor and so on. Solution to your problem, get a repairman to come check on it before you hurt yourself.
Posted on Dec 29, 2009
After driving the vehicle, turning it off, I walk out of it and get shocked while closing door. What is the problem?
you have an electrical problem somewhere a shorted wire could be touching the frame. Try checking your battery connections starter connections and wear rubber soled shoes
May 03, 2016 | 2001 Chevrolet Silverado 1500
Tip
How to avoid electrical fatal shocks?
Always keep in mind that if electricity is passed through our brain or upper portion of body where hearts & lungs are affected the electrical shock is likely to be fatal. To avoid electrical shocks and fatal shocks pl do following: 1. Don't touch electrical device or leaky cable with wet hands
2. Before doing any electrical job (even ironing) use clear hill chappal/shoe or stand on any insulator like rubber mat etc. 3. Always presume that any metalic body or cabinet or exposed metal part of an electrical device may give you shock and keep you ready with preventive measure as told above. 4. Switch off device and remove power cable wherever possible before opening/trouble shooting of electrical gadget. 4. The most important: if anybody gets a shock don't touch him/her with your hands. Just use your leg to disconnect him from electrical system. Otherwise electricity will pass through your heart making you lethal shock. 5. As neutral of a power plant is put into earth, the supply line has a tendency to close the circuit to earth through a load (conductor). Don't give any chance to make that 'load' with your body. So never touch live wire or insulate your body to stpo flow of electricity to the ground/earth and remember not to allow passing of electricity through upper part of body. 6. Don't do any electrical job after taking bath. Wet body gets very low resistance and helps in passing high amount of current during contact with live wire. Higher current through body means more danger for life. These small tips will protect you & your family members from any lethal shock. Pl teach this others also. Gautam Kr. mandal, Electrical Engineer, Durgapur
on Jan 19, 2010 | Kitchen Appliances - Others
Whwhat causes side-by-side freezer/refrigerator center partition to be hot to the touch?h
you got a short in the wiring from frig to the door get it checked stuff like that can burn your house down.
Jul 30, 2014 | Maytag Refrigerators
My kitchenaid side by side, he freezer door shock me. The icemaker works fine and the receptacle ground is secure.
Before you are electrocuted, unplug this and have a person skilled with electricity test it. You may have a broken wire somewhere, water in an area where only electricity should be, or who knows what.
Be blessed.
Sep 25, 2013 | KitchenAid (KSRD22FKST) Side by Side...
The jamb between the freezer & frig is very
It is common to be warm to the touch. If it is excessively hot then your door heater may be going out. Have a technician check it out. If this fails the doors will begin to sweat and drip onto the floor. Hope this helps. Good luck.
Aug 15, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Divider between doors has extreme heat for side-by-side model
there are 2 pipes running there to reduce the temp in the compressor its normal
Jun 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
I think i have a grounding problem with my Kitchenaid side-by-side fridge. I feel a shock when i touch the freezer door if i'm not wearing any shoes. Also i just checked the back of the unit and i get a...
I would buy a tester and check the wall receptacle to make sure the ground is right, they are like 5 dollars.Then yes you have a loose ground somewhere check the compressor first .
Dec 19, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Oct 27, 2008 | KitchenAid KSBP25FKSS Side by Side...
No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Oct 18, 2007 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,661 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
