Question about Sony STR-DE898 Receiver
Sony de898 no sound
I had a lightning strike a few months ago and my receiver quit working. No sound comes from it but everything turns on and lights up but no sound. I reset the receiver and everything I could do but I wondered if there may be a quick solution inside with a fuse or something I can do myself before i give up and decide its fried.
  • Sony Master
  • 5,568 Answers
Could be an internal fuse blown but most later electronics use a special kind of resistor called a varistor. These devices are across the AC line and do nothing until the voltage difference between the two lines, hot & neutral, exceeds a certain voltage; this is typically ~200 volts for 120 service as in the US and higher for 220 service on most of the planet.
They are disc shaped, will be from 4-5mm (~ 3/8") to as much as 25mm (~1") in diameter and if ever zapped, they are charred and with chunks missing.  When their design voltage is exceeded, their resistance drops from near infinite to a few Ohms which then causes the fuse to blow. You can replace the fuse and choose not to replace the varistor but then you will not longer have even that minimal protection against spikes.
For folks in lightning-prone areas, the installation of a 'whole-house' surge suppressor is highly desirable, will cost ~$250 US and have an insurance policy against losses of $10-$25,000 US in case you still lose devices protected.
Posted on Dec 19, 2008
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
Would replacing the main board fix my TV?
We can't predict what might have been happened during a lightning strike. If the TV is dead now; the main power supply regulator board [SMPS] board is fault. If so, you have to replace it first. then only we can get information about the condition of the main board. If the TV was connected to external Ariel or cable; before the lightning stroke; the possibility to damage to the main board too is there upto 80%.
In fact, if both of this boards are damaged, it might cost around 2/3rd of the total cost of a new TV.
The decision left to you. Do whatever you want.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2015 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Sony Bravia KDL-46S5100 There was a lightning strike and we lost power for a few minutes. When power came back on the only thing we have is a black screen and no sound. Is there something on our tv that...
Your Sony Bravia KDL-46S5100 might have been affected and damaged by the lightning strike. You cannot fix it without the help of qualified technician. It must be brought to your nearest service center.
Nov 03, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
Will not heat baby food for 13 seconds
Depending on the amount of Joules your household/microwave received your low voltage control electronics may have been fried by the lightning strike. For your own safety I recommend a new microwave.
Jun 10, 2010 | Maytag MMV5186A Microwave Oven
How to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
Apr 08, 2009 | Sony STR-DE898 Receiver
No sound
Did you have storms go through your area and lightning strikes or power surges? We did a few weeks ago and I have very raspy sound but perfect picture...
Mar 04, 2008 | Sony DAV-S300 System
Sony receiver optical sound "unlock" str-de898
Just fixed it, The Optical cable wasnt properly plugged in on the other end.
Found the fix here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRDE945&LOC=3
Oct 09, 2007 | Sony STR-DE898 Receiver
Sony STR-DE898 Receiver Logo
85 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
