Question about Reddy Heater-40,000 BTU Kerosene w/T'stat
Hi, I have two Reddy propane heaters that are suddenly on the blink. One (a Reddy RCP80V) has spark and fires up. The problem though is that after initial start of the heater flames shot out of the control valve area burning the control knob. My guess is that the tube assembly has a leak. Can I find a replacement part for this if this is the problem? The second heater is the ReddyRCP30. I have spark but no gas flow no matter how slowly I turn the tank on. Any help on these would be greatly appreciated. Thanks, John
  • Reddy Master
  • 3,286 Answers
It sounds like you have gas valve problems on both heaters john i would say best to get the local gas company to look them
Posted on Dec 30, 2009
  • 193 Answers
Need to replace valve,cannot be field repaired.You mat want to call 1-800-654-8534 for part. The mfg went belly-up
Posted on Sep 27, 2009
  • franktalk Sep 29, 2009
    Need to replace valve on #1 unit. Part number lpa2025.call 1-800-654-8534. Unit # 2 needs a pressure regulator
Reddy heater 75 125000 propane heater. Fan comes on, have spark, smell propane and still won't fire
There are couple possible reasons your unit refuses to fire; some units tjis big have to be level, this is a saftey feature bulit in if it is not level, it will not fire, ( it believes it has been tipped over), the smell of propane could also mean it has a leak on your line connection ( bad fitting, not sealed properly), finally check the temperature sensor may be bad and need replacing......
Jan 21, 2017 | Reddy Heating & Cooling
My reddy heater pro 100 wont stay lit when i let go of the trigger ive replaced the propane tank
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace and look in the small peep hole in the lower blower door and see if there is an led light that is flashing a certain number of blinks record the number and look for a diagnostic chart on the inside of the blower door or the upper side panel of the furnace if there is no flash code present you can try resetting the power to the furnace and see if the furnace will fire up.
Sep 08, 2011 | Reddy Heater RLP100 Portable Forced Air...
HAVE REDDY 55, I GET NO FIRE TO THE SPARK PLUG,
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
Can not start propane heater.
the thermo couple is bad.install new on and all will be well.give me the model number and i'll try to get you a part number
Mar 10, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 35
no fuse per se, but mounted on the round plate where the burner nozzle is and slightly to the upper right is an overload device with two red or white wires coming out of it. those two wires connect to two stab connectors on the capillary tube. you can try by jumping out those two stabs to see if the heater will fire up. if it does, then go to www dot desatech dot com and purchase a new overload. check for a good ground between the spark plug body and the machine metal part.
Mar 09, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-40,000 BTU Kerosene w/T'stat Logo
149 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
