Question about Samsung PS42P2S 42 in. Plasma Television
No screen signal
I have a tv that is a fiends that blew a main power supply fuse. I have replaced the fuse and now the relay operate and nothing will display on the screen except a very faint green glow. The menus wont work, it if their is a blown board but the problem is i wouldnt know where to start.
  • kent george Mar 31, 2007
    Picture of one of the boards and the filter/power supply
    Problem Solver:
  • 5 Answers
Send defective power boards to me, i will repair them.
ronniesemailaddress@yahoo.com
Posted on Feb 22, 2008
  • 86 Answers
Kentg..aussie yeah .have the same model doing similar but makes a buzzing noise .i downloaded a complete w/shop manual for this and my tech mate is coming around home to check it out .will keep you posted .it is not advisable to muck around in there as there are some pretty high killable voltages in there.. send email address..
Posted on Feb 11, 2008
Could be bridge rectifier
Posted on Jan 10, 2008
    Champion:
  • 217 Answers
You must start by checking the panel supply voltages, if you look on the panel inside the unit you should see a label with a lot of voltages on it, such as V-set, V-scan, Va, Ve, there are test points on the power supply board and DC _DC board, that has the test points and the small adjustors for those voltages, check and see if they are correct or not, then start unplugging the cables connected to the other boards and check all the voltages again, those supply boards have a latch on circuit that will cause it to shut down, if you have back lights though, it could be only a board swap, most of the time it's a logic board or main board or a Y-main board, but you poweer supply could still be defective, good luck
Posted on Apr 01, 2007
What is the 1 Amp fuse on the power supply driving?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 27, 2016 | Televison & Video
Screen went black/won't power on
This is a common problem
The first step is to check the fuse on the power supply board. Next, disconnect the inverter board to eliminate the possibility of it shorting down the main and or power boards. Be careful as the inverter board supplies high voltage to the cold cathode tubes (backlights) and it bites HARD. If you disconnect the inverter and the power led comes up then replace the inverter board. (The screen will appear blank because you have no backlighting). If the power indicator still fails to light you need to suspect the main board first before the powwer supply board. The main board tells the power supply board to come on. You need to check the trigger from the main board to the relays on the power supply board. Also check the power connector to the main board because you should see +12V and/or +5V on at least some of the pins. If no power on the relay triggers then replace logic board. Then replace Power supply board last. Or buy a new monitor!!
Oct 26, 2008 | Mag Innovision M572TVs LCD Television
Ihave 14 inch jcv tv first i thought it was dead bt then when i check i saw the fuse has blown i get new fuse to replace it and when i try to switch the tv it blows the fuse again & again .
Hi Aderajew, The new fuse also blew away means there is some shot circuit in the TV. No more fuse replacements please. There is nothing more you can do yourself.Take the set to some technician or a service center. Good luck.
Apr 07, 2015 | Televison & Video
Samsung PN51d7000ffzxa Plasma Screen does not power on, Power light blinks RED
if the power supply is a new one and you follow the steps described,ther`s no doubt,the main board is bad. good luck! from Mexico City.
Jan 24, 2015 | Samsung Televison & Video
No power and no glow to the screen. I'm assuming a power supply problem and I'm looking for a tear down of the unit. I also understand there are some fuses inside the case as well. Visual...
U have power to the tv is that correct?Yes?Power led light indication solid green,when tv is on but u have a blank screen no picture to the LCD screen panel at all?Yes?Than this problems it is not the tv power supply board problems.The tv Tuner signal board is it the cause and the problems.That the board where the incomming broadcasting signal cable plug into it.This board are 90%-95% are not repairable or troubleshoot able,because it almost all micro components parts and micro chips and most of them are surface mounted it on.This tv Tuner signal board can be only replaced with a new whole refurbish one only.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 11, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
My 32lg30 was shorted out during a lightining strike in a storm the other night. plug it in, and press power, and now nothing works. reset button or replaceable internal fuse? I am tech savvy so I can do...
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the entire power supply board, click this LINK.
Hope I helped you.
Thanks for using fixya.
Jdvillanueva
Jun 04, 2011 | LG 32LG30 32 in. LCD HDTV
I have a 2006 Hitachi Plasma 42HDS69 that will not turn on. When you power up the TV, the fuse blew. Replaced fuse, powered up the TV, could hear relay click in and fuse blew at the same time. Is this...
You have defective power supply board, Are you OK to strip it down and inspect the board? You will either have to replace the board or have it replaced/repaired professionally.
I hope I have been of help
Feb 14, 2011 | Hitachi 42HDS69 42 in. Plasma Television
AN SC547 ERROR ON MY RICOH AFICIO MP C3000 MACHINE
547 D Zero cross error § The zero cross signal is detected three times even though the heater relay is off when turning on the main power. § The zero cross signal is not detected for 2 seconds even though the heater relay is on after turning on the main power or closing the front door. § The detection error occurs twice or more in the 11 zero cross signal detections. This error is defined when the detected zero cross signal is less than 45. § Defective fusing lamp relay § Defective fusing lamp relay circuit § Unstable power supply 1. Check the power supply source. 2. Replace the PSU
Aug 26, 2010 | Office Equipment & Supplies
No power on 2002 Mitsubishi VS-60609
You have a short in the power supply or high voltage. You will need a sevice tech to deal with that problem. Make sure to get an est before repair
Jun 19, 2009 | Mitsubishi VS-60609 60" Rear Projection...
JVC AV-36260 TV Problem TV won't turn on
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
Samsung PS42P2S 42 in. Plasma Television Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
