Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Dishwasher not draining
Went to use the dishwasher and it had standing water from last cycle that was not drained out. I would close the door and could hear something trying to drain but nothing was ... the drain tube is clear but the washer now does not make any draining noises after trying it several times.
Is there a test to test the pump befopre replacement? Is there a overide to drain the tub besides running through a cycle again?
This dishwasher has not cleaned well from the start and i am tempted to trash it. What is the best one on the market?
I found my problem and it was related to the drain hose being plugged at the sink beather. As the hose gradually got plugged but chopped pecans ... don't ask me why my son figured the gaurburator would eat up the pecans ... but they accumulated and it acted as a restrictor and started to leave debris on dishes as the dishwasher would not completely **** all of the dirty water out of the tub due to the slowly increasing restriction caused by the accumulating debris in the counter breather assembly.
The solution was to disaasemble the breather by plucking the cap off and then uncrewing the top portion of the breather and cleaning all of the gook (Techincal term for Nuts, Hair, and other food matter) from the breather. Took 5 minutes and fixed the lack of draining problem and dramatically improved the overall operation of the washer ... it must have been like this for a long while. If you have debris left on your dishes check the breather for debris that may be restricting the draining of the dirty water from the tub
Posted on Dec 19, 2008
  • 157 Answers
Check pump for blockage and waste outlet
At the end of a wash cycle, when the door is opened, the spray arm continues to spray some water inside. Also, this sometimes coincides with water continuously draining out of the dishwasher which I...
at the end of the rinse cycle, it is normal to have some residual water spray from the jets. it is residual water pressure. If it sprays for more than a couple of seconds then it could be and obstruction in the fill valve or high water pressure. required pressure is 30 psi. Any water above the stand pipe will be drained out.
One last recommendation, this type of dishwasher needs to be fully drained (stand pipe removed) at least once a day.
good luck
Aug 26, 2017 | JetTech Jet Tech F-14 - Counter-Top -...
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Water is left in the bottom of the dishwasher after completing a cycle
When you find water left in the bottom of the dishwasher... most of the times there is an "Intake/Drain" flashing, or some other type of fault indication. The dishwasher has faulted out, in the middle of a selected program. The dishwasher won't even bother to drain the water out. If it's not a drain fault, then you can drain the water out by: switching the dishwasher off and on again; selecting a program; and closing the door. Open the door after 15 seconds and see if the water has drained out. If it didn't drain, there is a drain problem. If it did drain, then it can be several things. To better determine the problem, you will have to pay close attention to when the dishwasher faults out.
Nov 20, 2010 | Miele Premier-Plus Built-in Dishwasher
My dishwasher is not filling up water to start the washing cycle when the door is closed
Asuming you have an AM15, Check you have power to the fill valve during fill cycle. Make sure your drain is closed to retain the fill water. You should have 20 psi flow rate.
Jul 19, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
247 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
