Question about Directed Dei Valet 561r Remote Start/Keyless Entry
2005escalade remote starter
I have installed a valet 562t remote start in a 2005 escalade, the remote start will not start the car but will start it with the key on, after the car starts you can remove the key and it will stay started
  • Anonymous Apr 24, 2009
    I have a DEI Valet 471t that will not start my 2003 Ford F250 . The lights come on but no starting . Putting the key in the ignition will not start it as well . Is there a quick way to diconnect the remote to allow normal ignition starting ?
    Thanks for any help
My EVO-CHRT4 remote plug and play start will not start my 2011 dodge grand caravan in the morning but if i drive it for 10 mintues it will start it the rest of the day until the next morning.
Posted on Apr 26, 2018
  • 5,370 Answers
Either the remote keyfob is faulty or it needs reprogramming.
Keyfob remote not working ?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start the car?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Key Fob will not lock and unlock doors? http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks
Posted on Feb 18, 2012
    Sergeant:
  • 233 Answers
Did you install a "gm remote start bypass", like DEI model 556L?
if not it is the passlock that is not allowing the car to start.
Posted on Dec 19, 2008
2005 Cadillac Escalade no starter good battery no crank no start
no crankee, no startee. Sure battery is good? Battery contacts and starter contacts nice and clean and tight? Start solenoid getting energized? If not, why not? If so, is it any good?
Aug 28, 2017 | Cadillac Cars & Trucks
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
Valet 562t remote was in valet made & doors would only lock & unlock & now when i was trying to get out of valet mode it flashes lights but nothing more now. What could be my problem?
need to get the owners manual and follow the programing . cause what you are doing at this point is programing the alarm . basicly you are turn on and off features of the alarm try to function the valet switch.. and hitting the remote lock and unlock buttons . on some alarms you flip the valet switch and press lock or unlock button on the remote and listen for a certain number of chirps from the alarm to know what you turning on and off . that is why you need the manual so you know what feature of the alarm the number of chips is turning on or off when you hear them
radiorepair@windowtintingin239.com
Oct 29, 2013 | Car Audio & Video
Instructions on how to remove REMOTE STARTER on Dodge Durango
look in owners manual for how to activate valet mode.
Mar 23, 2013 | 2005 Dodge Durango
I have a Valet 562T remote start in my Ford F250. It will start like it should off remote but only run for about 15 to 20 seconds. It worked correctly untill I had a new oil pan installed. Garage...
You need to relearn the tachometer signal. Actually they probably did not hook up the tack wire when they put the new engine in. The tach wire is usually run to the non-common wire on one of the fuel injectors. Hope this helps
Jan 17, 2011 | Directed Dei Valet 561r Remote...
04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Jul 16, 2009 | Directed Dei Valet 561r Remote...
Occaisonally will not start
You need a new starter! if you go under the passenger side of the motor that's were the starter is and just hit it with a wrench a couple of times and it should start. Couple of my remote start customers thought the remote was the problem till i showed them this fact. The starter is under the vehicle
Mar 15, 2009 | 2005 Cadillac Escalade Esv
Car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Dec 16, 2008 | DEI Valet Keyless Entry System
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
657 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
