Question about Powershot Tool Company Cobra 8000 Forward Action Professional Staple and Nail Gun
I took apart this stapler and the pin fell out from pivot arm
Powershot Pro 8000I can't hold the pin in place while I try to put all the parts together
and I can't figure out how to replace the plastic guide in front.
Is there a schematic available?
In short I can't reasemble the unit.
  • 1 more comment
  • rgbort1938 Feb 05, 2009
    same as above- need drawings re assembly! NOW PLEASE AS I AM PISSED OFF!!!!!
  • Nate S
    Nate S Mar 28, 2009
    the staple gun is in pieces, and I am not what goes were.
    What a PITA
  • robrtolson Apr 17, 2009
    same problem. Spring on carriage came off hook. Tried to see how it was put together, but fell apart. I set the pin in place held by handle and release mechanism, but I can't figure out how to position plastic part. Power Shot web site still down. Any one try to call?
3 Suggested Answers
SOURCE: Need to reassemble Powershot 5700 stapler and need schematic
how to put the stapeler back together after fell apart
Posted on Jan 23, 2009
  • 384 Answers
SOURCE: what size staples do I need to use on the
The gun uses "T50" staples. Buy them at any hardware store.
Posted on Jun 17, 2009
How to put the spring back in the handle of Arrow T50 Stapler?
Ref. recocking the spring handle in your Arrow T 50 Stapler
1. secure the stapler in a vise. You need three hands to recock the handle spring.
2. Using a notched tack lifter hand tool, with one hand holding the handle so as to expose the spring, place the notched tool against the spring arm and force it to the rear. it will now be under tension.
3. Wiggle the handle into position so that you can quickly insert the clevis pin. Once secured, let go your handle that is now under tension. Replace clevis ring.
4. Dry fire to test.
Sep 18, 2014 | Arrow Staple T50 3/8"" Monel stainless...
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
How do I put the Bostitch B660 stapler back together?
MAYBE THIS IS USEFUL http://www.ereplacementparts.com/bostitch-21680b-industrial-fine-wire-stapler-parts-c-29443_29444_29449.html
Apr 02, 2012 | Air Tools & Compressors
My black & decker powershot would not reset, so I took it apart. Now I can't figure out where the plastic piece goes.
I used the photo at the website. I printed the picture of the stapler, and after 4 or 5 tries, got it back together. It works just fine. Thank You very much.
Dec 28, 2009 | Black & Decker 5700 Powershot Forward...
See above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Feb 02, 2009 | Black & Decker 5700 Powershot Forward...
The floorplate broke off my Floormate H3000
I'm assuming that the floor plate your referring to is the wheel assy. This is a common problem on the H3000 series. You will have to remove the two pivot brngs on either side of the handle where it pivots on the base. Once removed, flip the machine over and you will have the necessary clearance to insall the new wheel assy. The difficult part will be attaching the front arm assy using little plastic pin provided. You can use a small pair of needle nose pliers to guide the pin into place and then use a larger pair of needle nose to squeeze GENTLY to push the pin into place. Once done, re-install the pivot brngs and your done.
Jan 11, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Powershot Tool Company Cobra 8000 Forward Action Professional Staple and Nail Gun Logo
304 people viewed this question
Top Powershot Tool Company Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Powershot Tool Company Tool and Hardware - Other Expert? Answer questions, earn points and help others
