Lg6000 scarlett 47
I bought this tv 3 weeks ago and av 1 stopped working so i started to use av 2 but after a couple of days that stopped so i took the tv back and got it replaced i just wondered if you knew this was a common fault with lg LCD TVs.
  • sonderik Mar 19, 2009
    I bought a 47lg6000 scarlet around six months ago. After a while AV1 stopped working, all I got was a black screen and "no signal" message. After a week the AV3 in stopped working, and about one month ago the same happened to AV2. So now i cant use any analog equipment. Is this a common problem with these TVs? Is there any way to fix this except to get a new one?
  • 3 Answers
SOURCE: LG 47" 47LG50
Most likely it is not the TV; it's a grounding problem. Are all your devices plugged into the same power strip? They should be. Can you plug that power strip in to another outlet in the wall (even with an extension cord, just for testing purposes)? If that removes the lines, leave it plugged in there. If you can't leave it plugged in there, you'll need an isolator like the Jensen VRD-1FF or similar.
Hope this helps!
Posted on Jun 12, 2008
SOURCE: LG 42LB1DR OR LB1DRALCD 42"
I just went throught the same thing. It is the psupply. Have the 3 2200 capacitors replaced on PS. I just took out PS brought it down to a local place and 65 bucks it was fixed!.
Posted on Jan 23, 2009
  • 92 Answers
SOURCE: LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Posted on Jun 22, 2009
  • 92 Answers
SOURCE: same problem, vizio 47" LCD TV, six month old
change out the LVDS cable (the cable that go from the control board to the main board) and it should resolve your problem. If your TV is still in warranty, call 1-877-MY-VIZIO and they will set up an in home repair for free.
Posted on Jul 01, 2009
SOURCE: TLA-04011c 40in. LCD TV: Red light is on. TV
I have the same TV and I just replaced the Capacitors. It came with 2 10000UF 10V caps and I put in 2 1000UF 35Volt caps from radio shack. Its like brand new. There is even a video on how to change them on You Tube.
Posted on Nov 16, 2009
Defrost heater do not defrost creating poor air circulation
for starter call viking with your mod and ser #
there is a hinge recall on fridge door is covered by warranty regardless of age
it can cause the air channel from freezer to fridge to ice over due to too much humidity entering fridge
this stops cooling in fridge
the viking warranty starts from the day you took possession
defrost heater almost never
sounds like you need a better servicer
ask viking for other auth servicer in your area
gl
Apr 07, 2017 | Viking DFBB363L (20.3 cu. ft.)...
I had my TV 3 years...a week ago just wasn't able to switch to AV-1 or AV-2....I use one for my DVD player and the other for Wii...None of them working anymore...I mean the TV screen just shows...
Good Morning
On your tv there is one board that takes all those inputs and decides which to display to the the screen. It is not uncommon for these to go bad and one input or another will no longer work.
These boards can be replaced and are available most days on shopjimmy or ebay, However most people just use the inputs that still function until the tv dies.
Wish I had better news but that appears to be your problem
Have a great weekend
Nov 26, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
I bought a acer notebook on the 19th oct 2009 it was for a xmas present for my daughter i took it out off its box on 23rd dec 2009.In jan 2010 computer crashed took it back to currys they sent it away to...
1.Try to understand,without waranty not able to service your laptop without charge.
2.I thing you are not statisfing with acer service
3.In this scenario you go to consumer court with strong proof.(that means how many days of your laptop stay in service center only like that)
Nov 16, 2010 | Acer Computers & Internet
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
My drill stopped working and emits an odor... did it short circuit? I just purchased it 2 days ago, is there anything I can do to fix it?
If it was new a couple of days ago I would take it back where I bought it. I bought a power saw and used it once and smoke came out the motor. I took it back and they gave me a replacement.
Apr 12, 2010 | Craftsman 3/8" Corded Drill
Green double image
you need to replace both convergence ICs they are both STK392-110 and you can get replacement ICs at the following link and they provide free step by step instructions with pictures so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | JVC AV-65WP74 Rear Projection Television
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
