Question about Olympus DS-4000 Digital Voice Recorder
Memory Error I was dictating for about an hour of record time, set the recorder down for the night and when I went to use it the next day it showed a "MEMORY ERROR". I tried a new chip and it didn't help but it was 2 gigs and the recorder apparently doesn't support that large a chip. What should I do? I also tried changing the batteries.
  • dziff Jan 04, 2009
    The suggestion that I got from dictationmal was probably a good one but before I could try it out I noticed another idea - formatting the memory card - and tried that and was successful in getting the OLympus DS - 4000 working again. Thanks for the help.
    David
  • 145 Answers
You will need a new memory card, 1 gig or less, and not the new HS 1 gig cards. Look for a M type or get a 512 or smaller.
Posted on Jan 01, 2009
Card indicates memory error what can be done to correct this problem and also save dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
Jun 21, 2011 | Olympus DS-4000 Digital Voice Recorder
How resolve recorder olympus vn-3500pc memory error
could be corrupted memory. leave battery out of recorder for a couple days to allow the recorder to reset... get new batteries.
May 20, 2011 | Olympus VN6200 Digital Voice Recorder
I recorded a 4hour voice, and my battery ran out on the first hour. and when I erase the 4hour recorder. my recording capability went from 4hours to 1 and a half...what happened? how to get it's memory...
I turned my recorder on one day and only had 20 min of recording time and it was nothing on it took me awhile but i figured it out you have to put it on your pc and reformat it when i did that i got back my 26 hrs of recording time hope that helps
Jul 20, 2010 | RCA RP5022 Digital Voice Recorder
Can not get it to unload all I have recorded
It could be corrupted file. Try downloading one file at a time through My Computer. After you have exhausted all possibilities, format the recorder through the recorder (not the computer) and your memory should be fine
Feb 16, 2009 | Olympus WS-311M Digital Voice Recorder
Olympus DS4000 says Memory Error
I had several cases lke this with clients. One of the dictations is corrupted. It's the "one" here that matters. When you connect the DS-4000 to a PC, it appears in your "My Computer" as a Removable Drive. Browse this drive, and you will find the dictations in one of the folders (A, B, C etc...) or they might be scattered between folder depending on how your user records.
Try to copy dictation manually from that drive to the matching folders on the PC (by default My Documents-->DSSPlayer-->Messages-->FolderA, FolderB..., although you might have changed that).
At some stage one of the dictation files will refuse to copy/paste: that's the corrupted one; however should should be able to save the others. Once you have salvaged all but one dictation, you can do a format of the card. In fact, I suggest you chage the card, as corruption is usually a sign of worst things to come...
Using this procedure, at least only one dictation will need re-dictated.
I hope this helps.
Dec 30, 2008 | Olympus DS-4000 Digital Voice Recorder
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
May 10, 2008 | GE 29888GE1 Digital Answering Machine
Memory Error
I would suggest the XD card is corrupt. You may be able to copy the recording off the machine by copy and paste in windows explorer. If not then they are lost. Data recovery will not work very as the files are recorded in dss format.
Only option is to format the card on the PC.
Apr 23, 2008 | Olympus DS-4000 Digital Voice Recorder
Lost Recordings
Very odd problem. If the unit has a problem with software, it won't work at all. I've never seen a unit delete ALL the shows, unless someone initiated a clear and delete everything from the reset menu.
Was the unit in guided setup? or was everything (channel guides, settings) the same and your recordings were just gone?
Dec 17, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Olympus DS-4000 Digital Voice Recorder Logo
428 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
