Question about Heath Zenith SL-6136-WH Basic Solutions Wireless Switch and Plug-in
The light fixture stopped working.
It's not the breaker. It's not the light fixture - we tried a new one.
  • kbalter Feb 14, 2009
    The light switch worked for 2 times now it will only go off if light has been turned on from the hard wired light switch. I have already changed both switches - and we do not have rats. Also, breaker is fine
    Master:
  • 413 Answers
Try installing a new switch if you haven't already. If you have make sure the wiring is correct and if all seems fine turn the breaker off and make sure its "hard" to reset, if not it's most likely the breaker... Unless you have a rat problem
Posted on Dec 19, 2008
Installed light fixture & Now No Light
It would be helpful to know which timer you have. But from what you mention, there is another switch involved. Was this on a three-way circuit? That is, was this light controlled by two separate switches? In that case, you need to know which wire goes to the live and which to the light. Not easy without a tester.
Other than that, send us the switch make and model number and we can look at the wiring diagram. Cheers.
Jun 29, 2015 | Hardware & Accessories
Replaced ceiling light fixture because ceiling fan and lights stop working but now the new fixture not working? there is power to the ceiling light fixture? what is wrong?
With the power off, make sure the connections are correct and tight. Check the fuse/circuit breaker and switch in that order.
Mar 23, 2015 | Dryers
How do I stop my hunter's ceiling fan from causing the breaker to trip?
Is it a new installation? Your ceiling fan should never trip a breaker unless it has a problem in the fan or light fixture attached to it.
May 27, 2014 | Hunter Fan 27185 Light Remote Control
No volume on tv after purposely tripping circuit breaker
Try returning to the initial setup procedure in case some setting changed as a result of the power interruption.
Dec 09, 2013 | HP PL4272N 42 in. HDTV Plasma Television
Replaced sylvania 26 w 4 pin in overhead light fixture and it is not working
replace the ballast almost always these lights do not usually burn out the ballasts go bad
Dec 13, 2012 | Lithonia Lighting Fluorescent Flush Mount...
We have a new 12 room motel addition we are wiring. There are two bathrooms in which the arc-fault breakers are trippping. The loads are - two three lamp incandescant wall fixtures, and two GFCI...
Hi, I know it sounds simple but sometimes its the simplist things that get you. Check your earth, as it sounds as if this may be causing the problem.
Sep 28, 2010 | Eaton ARC FAULT CIRC BREAKER
We have 2 identical fans in 2 different bedrooms. I had an aircompressor going and my daughter was running a blow dryer and it blew the breaker. Now both fans don't run, but the lights work. ?? the black...
Do me a favor, prior to reading on any further; did you try pulling (or turning) on the fan chain? As simple as this sounds, I've experienced this before. And I'd rather you try the simple solution first, before opening up the fixture. Okay, if that didn't work - the first TURN OFF the light switch or circuit breaker before working on these fixture's. If you're not well schooled in doing electrical work, I'd advise turning the circuit breaker off along with the wall switch. Now, when you open up your fixture, the black wire should be hooked up to the fan motor(s) lead wire; and the blue wire to your light(s) lead wire. Now, if both your fan and light were working before, then the wires at the fixture (black/motor and blue/light) were wired together. If so, then it could've blown both motor(s)? But I don't believe it did. Now that you've checked everything out, and your ready to turn the fixture back on. Keep the wall switch in the off position. Then go turn on your circuit breaker. If everything holds, then turn the wall switch on. It's done in this manner for safety reason's. Try this, and then let me know how it went. You should be good to go. Good Luck, and feel free to contact me again if you have any problems. Jim
Mar 16, 2010 | Hampton Bay 52 In.Carriage House II in...
Wire connection from lighting ballast
What you do is cut the wires from the old ballast that feed to the fixture end connectors then 'wire nut' the new ballast wires to the old wires.
Oct 02, 2009 | Electrical Supplies
I was changing a light fixture in my bathroom,
hello, all you have to do is to get a new breaker with the same amperage or amp's example 15 amp's of the breaker that's blown and pop out the old one and put in your new one , in the future when working with electricity always manual trip the breaker before working for your safety and the safety of the equipment .good luck
Mar 22, 2009 | Your One Source Homeline Circuit Breaker
Kitchen lighting problem.
Open neutral. check the fixture/switch closest to the bkr panel that is not working for a bad connection in a wire nut, if not there, move to next fixture/switch closer to the panel
Feb 10, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Heath Zenith SL-6136-WH Basic Solutions Wireless Switch and Plug-in Logo
411 people viewed this question
Top Heath Zenith Electrical Supplies Experts
lakeareaserv
Bob Kirkwood
Gene Haynes
Are you a Heath Zenith Electrical Supply Expert? Answer questions, earn points and help others
