Question about Whirlpool Refrigerators
Falty Thermostat Where is the Therostat on a wherlpool side-by-side Refrigerater located?
Solved at the cost of $232.00 Thanks
Posted on Dec 20, 2008
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
Were is my therostat locate
HI, you will find the thermostat on the drivers side of the engine. If you follow the large upper coolant hose down the side of the engine you will find a housing its attached to. Good luck.
Aug 25, 2010 | 1997 Lincoln Continental
Where is the engine therostat located, 1993 1.8 ltr,
to find the thermostat,just follow the upper radiator hose till it ends,which is next to the battery.the thermostat is located right under the metal part that the upper radiator hose is connected to.it has 3 10mm screws holding it in place.just remove these 3 screws and pull it off and bingo,there is your thermostat.i'm sorry but i can't help you with the location of the ecu.hope at least the information i gave you helps.good luck and take care, manny
Jul 02, 2010 | 1993 Toyota Corolla
My under the counter sub-zero refrigerator does not work. if I by pass the thermostat it will run and cool. could this (thermostat) be the problem? how hard is it to replace the therostat?
Yes the thermostat seems to be your problem. It shouldn't be hard to do but Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Refrigerator-
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
Feb 10, 2010 | Refrigerators
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Where is the thermostat located on a 1986 diesel VW jetta
The top radiator hose goes into the thermostat housing and then into the motor. The therostat should have two bolts take them off. And theres the thermostat.
Nov 29, 2009 | 1986 Volkswagen Jetta
Where is the therostat located on the 1999 Olds Alero 2.4 liter?
Follow the top radiator hose to the engine, it is connected to the thermostat housing, the thermostat is inside that housing.
Nov 17, 2009 | 1999 Oldsmobile Alero
2000 ford escort therostat not working right
Replace the thermostat first. Make sure the antifreeze level is full. Bleed the system. most car's have a bleeder valve located at the thermostat housing outlet.Drain the coolant level only to below the thermostat where it won't leak when removing the housing and thermostat. If it's the heater core it is located under the dash where the 2 heater hoses enter the cab from the engine compartment.
Jan 22, 2009 | 2000 Ford Escort
Whereis the thermostat located on the olds bravada 1998
Follow the top radiator hose to the top of the engine/intake remove the hose and move to the side then take out the two bolts holding the thermostat housing to the intake remove and install the new stat and gasket.
Jan 07, 2009 | 2000 Oldsmobile Bravada
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
