IPOD went through washing machine. Won't switch on
  • 502 Answers
Push center and menu buttons as you keep it connected to the computer charger. That will hard reset the ipod. If it doesn't respond to the hard reset it is more likely you have motherboard issue. You can try to open it and clean the corroded parts on the logic board. If that doesn't help, there are parts available on ebay, there is a ipod repair guide that will show you how to open your ipod replace the logic board.
Posted on Mar 06, 2009
    Sniper:
  • 59 Answers
Ya it's done.. Ipods are not water proof to any extent of the imagination. Unfortunately it looks like you'll have to get a new one. THe repair cost on that will exceed the cost of replacement since you'll have to pay for labour. Also water damage is not covered under the apple warranty.
Posted on Dec 19, 2008
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
May 26, 2011 | Hoover HTC243 Top Load Washer
Agitator won,t work tub will fill, and empty but won't spin and agitator won't work
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 01, 2010 | KitchenAid Washing Machines
Ipod was in washer (and dryer) and works fine, just no backlight, any way i could fix it myself?
I dont know how U can fix it but one thing your Ipod rocks mine went throught the waster & dryer and broke apart
Apr 03, 2010 | Apple iPod nano 4th Generation
I left my ipod shuffle in my washing machine.Now I cant get it to work,or to charge it!
If it actually went through a wash cycle I don't think that theres much hope of it working again.
Mar 25, 2009 | Apple iPod shuffle MP3 Player
Doesn't work at all
there isn't much you can do at that point unless you can narrow down what part is failing. most likely, the mother board is shorted somewhere. there are companies that do repair them but you might be better off getting a new one.
Nov 12, 2007 | Apple iPod nano 3rd Generation
201 people viewed this question
 Grubhead
Grubhead
