Question about Lisle Serpentine Belt Tool & Accessories - Expanded Model
What do I need to change a serpentine belt on a 1997 Dodge Grand Caravan?
  • 1,757 Answers
For the 1997 Dodge Grand Caravan Serpentine Belt:
Did not specify what Size Engine: 2.4L, 3.0L 3.3L, 3.8L.
Click on the following free direct Link. It has several of the Serpentine Belt Diagrams and Tensioners that are possible with your Size Engine (2.4L, 3.0L, 3.3L, 3.8L) and engine options (AC/No AC, etc.).
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
http://www.2carpros.com/car_repair_information/year/1997/make/dodge/model/grand_caravan/1997_dodge_grand_caravan_drive_belt_routing_diagram.htm
"HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them
Posted on Apr 01, 2010
2 Suggested Answers
SOURCE: Serpentine belt diagram for 1994 dodge caravan v6
For two long days I tried to get help on the internet but all I ended up with was a virus. I ended up getting a diagram from a local parts store,and it didn't cost anything.
Posted on Feb 11, 2010
Serpentine belt diagram 2010 dodge grand caravan 3.8 L
Had to go to paint and draw it. It should be close, hopefully.
May 20, 2018 | Dodge Cars & Trucks
Diagram for 2010 dodge caravan serpentine belt 3.3l
i need to see a diagram for a 2010 dodge grand caravan with a 3.3 liter It has air condtion
Aug 08, 2012 | 2010 Dodge Grand Caravan
Need serpentine belt diagram for 1994 dodge grand caravan
if you buy your belt from Autozone the belt routing is on the box
Jan 09, 2010 | 1994 Dodge Grand Caravan
Replace serpentine belt on 3.3 L 1995 Dodge grand
I go to the local parts store & buy a repair book for the vehicle for approx. $20, read the procedure in the book, gather the tools & parts required, replace the belt per the instructions
Oct 11, 2009 | 1995 Dodge Caravan
Dodge Caravan 2,4l 1997 timing belt change
you will need to change the belt tencioner aswell
if you havent don a cambelt before dont see youre local mechanic ok m8
Jan 03, 2009 | 1997 Dodge Grand Caravan
I need a 1998 Dodge Grand Caravan serpentine belt diagram.
The belt routing diagram is shown on a decal located on thehorizontal metal support above the radiator and under the hood support rod (passenger's side near the coolant overflow tank).
PT Stanley
Dec 03, 2008 | 1998 Dodge Grand Caravan
How to replace serpentine belt?
how to remove and re-install serpentine belt?
Nov 20, 2008 | 2000 Dodge Caravan
Serpentine belt replacement
What engine do you have? The 3.3 and 3.8 engines have a single serpentine belt, and a belt tensioner, so no adjustment is needed. Did you replace the tensioner, and want to know how much to torque it? countrycurt0
Jul 20, 2008 | 1998 Dodge Grand Caravan
Serpentine belt diagram:
The belt routing diagram is located on the top radiator cross member by the hood latch. You should see it when you open the hood. If it is not there, all Chrysler, Dodge, and Plymouth minivans, from 1993 to at least 1999, used the same 3.3L engine setup, so find someone with one and look for the diagram where I described.
Jun 27, 2008 | 1993 Dodge Caravan
Lisle Serpentine Belt Tool & Accessories - Expanded Model Logo
379 people viewed this question
Top Lisle Hammering Experts
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
