Question about Honeywell HWM-450 4 Gallon Humidifier
Cleaning water tray
I just purchased a Honeywell humidifier HWM 450 The manual states it should be cleaned before first use. First it states to remove the water tray. Then, it says to pour 1 cup undiluted white vinegar into the tray.
Obviously, once removed, the liquid will run out. So- I need to confirm my assumption that the vinegar needs to be added while attached to the humidifier. Is this correct?
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Posted on Jan 18, 2009
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
Apr 29, 2012 | Honeywell HWM-450 4 Gallon Humidifier
Need replacement o-ring for water tank cap
This is a posting from someone other than myself...however, it presented a good solution.
A solution to the problem with the fill cap failing/leaking. It was/is not the cap, it's the gasket/grommet/o-ring. Remember "THE MAGIC BULLET", well the gasket, that's where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Recommended:
Yes
Amount Paid (US$): 45.00
Battery Life: N/A
Noise Level: Almost noiseless
Dec 24, 2010 | Honeywell HWM-450 4 Gallon Humidifier
Warm Mist HWM-2030 Humidifier: DOES NOT GIVE OFF VAPOR...
If the unit runs normally otherwise, but doesn't give off vapor, then your heating element is the culprit. i.e. if fan runs, switches in normal positions, indicating lights on, etc.and restart slide switch depressed and no mist, then, yes the heating element is the source of the problem. It may be bad, or otherwise it may just be scaled up from hard water, and require cleaning.
You may refer to your users manual, or if you no longer have a copy, you may download one at this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this answers your question.
kcomp1863
May 18, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
Dec 31, 2009 | Honeywell HWM-450 4 Gallon Humidifier
I don't know how or what to clean it with.
Just mosted the user manual to this site, which contains the cleaning instructions. Also, you can download the manual directly here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
May 18, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
Need Replacement Tank for HWM-450 humidifier not under warranty
the website that you can go to to order is www.appliancefactoryparts.com. type in your model number, clickon a picture once it loads and then scroll down the page until you see water tanks. right now the price is 39.99
Feb 24, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Honeywell Warm Mist HWM-2030 how to clean it ?
Just uploaded the user manual to this site, which contains the cleaning instructions. You may also download the manual directly here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
Nov 23, 2008 | Honeywell Warm Mist HWM-2030 Humidifier
Unit turns off Mid Stream
The part of the machine that draws water up from the bottom, as well as the bottom tray, need to be cleaned from time to time, or it cannot accept water and will indicate the tank is empty. After removing the tank, unlock the top from the bottom by moving the small lever in the area the tank sits, then pull the entire top section off of the bottom tray. Dump the old water out, then put a solution of vinegar and water in the accepting section of the tray. Replace the top and let that set for a few hours to remove buildup. You may need to use a silicone scraper or something if there is significant buildup. Pour out the vinegar solution and rinse all of those sections off with clean water. Replace the top, lock the bar, and return the tank. Your problem should be fixed.
Oct 14, 2006 | Honeywell Warm Mist HWM-255 Humidifier
Open Questions:
Honeywell HWM-450 4 Gallon Humidifier Logo
321 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
