I have a ca. 10 year old Estate by Whirlpool top-loading washer. Model number appears to be sm8280867. The machine fills with water, and agitates, but then stops. It will not enter the rinse cycle. My first concern is getting the wet clothes out of the machine. Is there a valve to manually drain the water? Is it worth trying to fix it myself, or should I get another washer. I am pretty handy around cars and motorcycles, but don't know much about washers. Thank you.
SOURCE: washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then
will not spin or drain, you more than likely have a defective lid switch.
If you open and close the washer lid and do not hear a “clicking” sound, the
switch has probably come loose, or has broken.
There are two mounting screws that hold the switch in place along the
washer rim. Also, inspect the lid to
ensure the small plastic piece that pushes down on the switch when the lid is
closed has not broken off. This is
called the “lid strike”. If the lid
strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to
replace the switch, you can click on the following link for advice on how to replace
it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get
replacements parts, please let me know.
I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the
switch. Once the switch has been
replaced, the washer should spin and drain, which will prevent you from needing
to bail water.
SOURCE: washer machine drains while filling
If the pump is actually coming on at all times, then I imagine this machine has a completely electronic control system ? - i.e. No mechanical timer ? - If this is the case, then the switch that controls the pump is an electronic solid-state device, or, more rarely, a relay on the board. Looks like you'll need a new power board.
SOURCE: whirlpool gold top load washer (7 months old) won't agitate or spin
It sounds like the motor drive coupler has broken. This means the motor is no longer turning the gearcase, but it is turning the pump. It will be repaired under warranty if it is only 7 months old. You should have a full one year warranty on the washer. If not, he can probably fix it, but it will need a new coupler. He can tilt the machine back and see the coupler between the motor and transmission from underneath. I can walk you through replacing it if you want, but I wouldn't recommend it if it is still under warranty. There could possibly be something more major wrong that has caused it to break and some of the factory servicers are real picky about customers working on a machine under warranty. If you need it running tonight, he may be in trouble. Post back if you need further help or have more questions. Thanks/mike
SOURCE: kenmore washer won't drain
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
